Car died, no reason found .....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simplifying, Nov 15, 2016.
  1. simplifying
    simplifying Junior Member
    33
    Lawrence, Kansas
    2016 Toyota Prius suddenly stopped at an intersection waiting for stoplight as I started out to do errands on Saturday. Tried to start it several times, called tow company to haul to the repair shop. Repair shop said it started fine, took it out a few times to drive.
    The car did not even turn over, there were no lights on the dashboard and so I could not read what was wrong with the car. The emergency lights worked. 119,000 miles, 12 V battery replaced a couple of months ago.
    Thankyou!
    49,380
    what do you mean by, 'car did not even turn over'?
    i suspect the battery connections may be loose, especially the negative to ground.
    Patrick Wong likes this.
  3. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I hope you mean 2006 Toyota Prius; otherwise you've been very busy driving. The 12V could still be part of the problem if it is not getting charged properly.
  4. Mendel Leisk
    38,649
    Yeah, I think you've got it. I was a bit gobsmacked by that mileage.
    Raytheeagle likes this.
  5. bisco
    49,380
    i started to type, 'why would you have to install a new 12v in a 2016', until i saw the avatar.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Maybe they are channeling their inner @2 fas 4 u ;).
    Aaron Vitolins and Mendel Leisk like this.
