Car dies because only a quarter tank of gas?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by adriennepratt, Jul 30, 2006.
  1. adriennepratt
    adriennepratt Junior Member
    I like to know what you think about this everybody.
    Our 06 Prius simply died on us a couple of days ago (in the middle of searing heat with a newborn baby on board, great, huh?). It refused to turn on when we got back in after leaving it off about an hour, and we got several warning lights - the red triangle with exclamation mark, round orange circle with exclamation mark, AVS and the orange engine (excuse the lack of technical description), all of which the manual told us meant that we should take it to a dealership. We left it turned off for a few minutes and then it came back to life briefly (still with warning lights though) before dying again. So we got it towed.
    The service guy told us that the problem was low gasoline, and that this was a Prius quirk - sometimes it thinks you have more gas than you do. But we still had two bars, which normally lasts us for days and days (we don't drive too much). We didn't get a low gasoline warning either, as we normally do.
    I'm pretty upset at this as it was a really traumatic event given the baby and the heat. And the cost of the towing. I'd really like to hear if you think the service guy's explanation sounds reasonable and if not, what the problem might have been. I would really like someone to refund the cost of the towing!
    Thanks so much,
    dri
  2. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(dri @ Jul 30 2006, 10:52 AM) [snapback]294608[/snapback]</div>
    Complete BS, if you've had all of your Special Service Campaign (SSC) work done. Did you?
    EDIT: Just noticed this is a 2006 Prius we're talking about, here. I don't believe there were any fuel bladder/system SSCs on the '06 model.
    Did the service person pull any codes from the car, or just tell you that you were "probably out of gas?"
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    what were the codes that they pulled? until you get them and there should be several with all the lights on, I'd have to believe Brandon on their explanation. With out the low warning light coming on there should still be a couple of gallons of gas left in the tank. If his explanation was correct there would be dead Prius all over S. Cal and AZ.
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    did you recently fuel your car on a surface that wasn't flat? if you run out of gas with a couple bars left the inclinometer may be off.
  5. tdub1974
    tdub1974 New Member
    Greenwood, IN
    The same exact thing happened to me yesterday (one bar, not blinking instead of two but still...) I went on electiric for about a 1/2 mile then nothing. I was about a 1/2 a mile from a gas station and bought an gas can and a couple gallons and then went to fill up. Then all was good, but concerning. Even more odd is I only filled up with 10 gallons (including the 2 from the can). And I pumped slow... etc etc. all the stuff I normally do. What gives?
    I survived, after also thinking someone stole my Prius fro the side of the road... and calling the police. Long story....
    If anyone else has ideas, I'd love to hear them. Never the less, I think I will always fill up at 400 miles to be safe!!
  6. richard schumacher
    7,663
    1,038
    United States
    How many bars were on the gas gauge when you left it? Is it possible that you did not turn it OFF for that hour? It's easy to do if you're distracted or in a hurry.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Get the codes and let us help you!
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    sounds like BS.
    Now.. if you ran out of gas, they may have programed the prius to be similar to the RX400h computer. Three failures to start on the Gas engine and the computer locks you out. Tow to dealer, no pass go or collect 200... shucks...
  9. adriennepratt
    Thanks for all your responses! (I didn't realise I had got any because I thought I would get email notification).
    Richard Schuhmacher - We had two bars on the gas gauge and we couldn't have left it on because we have the Smart Key system which won't let you leave it on and move away from the car. What we had done was have the car running with the AC on for maybe an hour or two earlier in the day while we were waiting in different places in the car. But I would have thought that would just use up the gas and reduce the number of bars in the indicator. We definitely had two.
    Galaxee - no refilling on sloped surfaces that we can remember.
    Everyone else - On your advice I called the service guy and asked for the codes - he was anything but helpful (how dare I question him?), but the end result was that he didn't write the codes down. He says there were three and they all indicated low gasoline. He repeated that we should never let it fall below a quarter tank of gas (which on this occasion we actually hadn't).
    How can I get to the bottom of this? I am worried it will happen again, and I also want to get reimbursed for the towing fee. Do I contact Toyota with this guy's story and see what they say? Would the codes still be on the computer and is it likely that Toyota will help me to find out what happened?
    Thanks again to all,
    dri
  10. philwojo
    philwojo Member
    104
    Darien, IL (West Burbs of Chicago)
    <div class='quotetop'>QUOTE(dri @ Aug 3 2006, 11:31 AM) [snapback]297006[/snapback]</div>
    DRI, you can leave the car running with the SKS and walk away I do it all the time. I put the key in my pocket, start the car, forget something in the house and run back in, at least 50ft away, and the car does not shut itself off.
    But, being you had 2 pips left on the gas gauge, it should have been fine. This is the 2nd post on this I have seen in 2 days and both service people said almost the same thing, I think Toyota needs to step up and send out a bulletin to their Tech's letting them know that you can go all the way down on gas, and you don't need a 1/2 or 1/4 tank when you fill up.
    Phil
  11. richard schumacher
    7,663
    1,038
    United States
    Umm, no, SKS won't let you *lock* it while in READY. You can certainly leave it in READY and walk away, and it will keep running. It will beep at you briefly, but the beep could go unheard.
    Or there could be a problem in the fuel gauge. Take it to another dealer. The one who wouldn't give you the codes sounds less than helpful.
  12. daronspicher
    daronspicher Active Member
    1,208
    I really don't know anything other than to say I believe your story based on my own experience.
    2 days ago when Chicagoland was smokin hot, I had 2 bars left when I went to fill up. I put in 10.474 gallons. I drove away thinking... That was odd, over 10 gallons when 2 bars remaining...
    I do 10+ gallon fillups regularly, but typically have been on 1 bar for 20 or more miles or even had it blinking.
    The super-hot thing could be throwing these cars off their calculations..
    Is there an actual dipper thing in the gas tank that checks for actual liquid, or is the fuel gague based on amount of gas used on the mfd calculator somehow? Maybe on how much air gets into this bladder thing... Who knows the fuel tank?
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    'Triangle of Death Event'
    This happened to me as well last December after having it for just two weeks. But I was driving with the warning light on trying to get to my normal station. It shut me down so I drove a short distance to an alternate station. What surprised me is that the pump shut off and I was only able to pump 9.5 Gal.
    BTW is your Prius new? Less than a month old?
    OTOH now that it's warmer, and the bladder is more flexible(?). I get down to one bar and on fillup find that I'm putting in 11+ gal ( 11.6 once :eek: ). The more I've driven the vehicle the more it seems to be able to take. True I bought it in winter and have done most of the driving in Summer but it seems that the bladder is able to take more fuel more consistently. It will be interesting to see what happens again when it gets cold and the bladder is not as flexible.
  14. 200Volts
    200Volts Member
    429
    43
    Northern CA
    My new 06 ran out of gas 10 miles after the last bar started blinking!!! I pulled over right away, on a dead flat area (prior fill up at regular station, flat pad as usual)
    Yes, I had 520 miles already on the tank so I should have known better. I usually just wait for the flashing light-warning and get gas.
    Odd thing though, the AAA guy dumps 3-4 gallons in (from a 5 gallon can) and when I start the car the gauge goes up to almost 3/4 of a tank!!!!!!! WAY WRONG.
    After 5 minutes of driving it drops down to about 1/3 tank !!!
    TOYOTA are you reading this? Something is WAY off as far as repeatability of the gauge. Is it sticking or what?(bladder?)
    This was at the week end of 113 F temperatures.
    (same post in Fuel Economy Forum)
  15. Lil Mo
    Lil Mo New Member
    171
    <div class='quotetop'>QUOTE(galaxee @ Jul 30 2006, 10:14 AM) [snapback]294649[/snapback]</div>
    Sorry for asking, but what is the "inclinometer" and how do you get it to reset?
    Does anyone think that the problem is an issue with the 2006?
  16. galaxee
    9,810
    465
    MD
    the inclinometer is involved in determining whether the car is on an incline and interpreting the fuel gauge's output accordingly. there's a rain-dance like procedure posted on the boards that some have gotten to work and others haven't. however, if you haven't fueled on an incline it's a non-issue.
    for those of you curious, the fuel gauge has a float with a magnet attached, the magnet's position determines what's on the fuel gauge. the gauge is slow to change to ensure that the change in position is due to fuel levels actually getting lower and not a temporary road-related event.
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I have not read through the whole thread. But has anybody suggested that water in the gas might be the cause? This would jive with the evidence is the uptake on the Prius bladder is on top of the bladder. Since the gas is floating on the water (I think I have this right?), as the fluid in the bladder is used up, eventually the water is being delivered to the fuel system.
    I routinely run down to one pip and then refuel. No problems. Just after the change from 2 pips to 1 pip, I visit the gas station. I figure I can do this as the bladder keeps water condensation out of the gas as no atmosphere is sucked in as gas is used. In my previous cars I would have refueled at 1/3 to 1/4 (rather than 1/10 th on the Prius) of a tank to avoid exposing the air volume to too much condensation.
  18. hill
    8,188
    Unfortunately, your avatar doesn't say what area you live in. Most states have "Lemon Laws" ... and if your state has one similar to many ... I'd call the Toyota manager first, tell 'em about Mr. Indignant's response to your car being out of gas at 1/4 tank ... and kindly remind him/her that "only 2 more times" and THEIR Toyota Dealership will be giving you a FULL refund (including Tax License) and that car will be on the "Lemon list" so they'll have to unload it cheep, or alternativly, you'll be taking ownership of another new Prius. I probably shouldn't, but I always enjoy making the arrogant/dummies (Zoolanders, if you saw the movie) of the world, shape up & fly right.
  19. Bob64
    1,540
    92
    Virginia
    Bladder on top of bladders? Theres only ONE bladder to my knowledge. The gas bladder.
