car does not READY
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Nov 11, 2017.
  1. franken1313
    franken1313 Member
    216
    26
    US
    Car gives error message on screen P LOCK ABNORMAL. No OBD codes. Car does not ready unless I disconnect a wire in the fuse box wait a few seconds & reconnect the wire.
    51,140
    how did you stumble on that particular wire?
    how is the 12v health?
    kenoarto likes this.
  3. franken1313
    franken1313 Member
    216
    26
    US
    12v is 12v car off with a load & 14v When ready. I discovered the wire bc I was checking the fuses & I just disconnected that cable just bc no real reason & now everytime I turn off the car the car will not turn on unless I disconnect that cable for a few seconds
    51,140
    12v is low. what load with car off?
  5. JC91006
    16,672
    8,518
    You need to get the codes read, it seems to have a high voltage leak.
    Mendel Leisk and Raytheeagle like this.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Is that 12v measured after not using it overnight?
  7. franken1313
    franken1313 Member
    216
    26
    US
    Yes I've checked it after not using the car for days
  8. franken1313
    franken1313 Member
    216
    26
    US
    I have a generic obd2 reader but that shows no codes
  9. JC91006
    16,672
    8,518
    When you disconnect the 12v power source, it'll allow you to start your car 1 time, but the bad part, it'll erase all your codes. So you'll need to read the codes before disconnecting the power source
  10. franken1313
    franken1313 Member
    216
    26
    US
    I don't disconnect the 12v only that wire.
  11. JC91006
    16,672
    8,518
    I believe that wire disconnected the 12v power source
  12. franken1313
    franken1313 Member
    216
    26
    US
    I have disconnected the 12v battery only & that doesn't let the car turn on only that wire does.
  13. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    A generic obd2 reader may not offer relevant hybrid codes.
    You might want to look into obtaining a mini-vci cable ($20, you also would need a laptop) or and elm327 device ($3+, you would also need an android type device).
    Raytheeagle likes this.
  14. kenoarto
    398
    Chicago, IL
    If you haven't already replaced the 12v battery, try testing again, after an overnight non-use (of any kind). This time include the percentage point.
  15. JC91006
    16,672
    8,518
    It's probably not a 12v problem as he's able to start the car after some type of reset procedure.
  16. kenoarto
    398
    Chicago, IL
    Do yourself a favor. Test the battery per instructions on the link. Report your levels here. Low 12v batteries have been known to create all kinds of wacky symptoms.
  17. kenoarto
    398
    Chicago, IL
    That "reset" is a jiggle of a wire.
  18. franken1313
    franken1313 Member
    216
    26
    US
    I just purchased a new 12v battery last week & the one I replaced was a yellow top optima that was only 1 year old.
  19. franken1313
    franken1313 Member
    216
    26
    US
    The reset is more disconnecting & reconnecting that wire in the fuse box
  20. bisco
    51,140
    so let's recap:
    1) 12v is low
    2) you have an inadequate code reader
    3) you're disconnecting an unknown wire to get it to restart
    4) am i missing anything?
    Raytheeagle, kenoarto and SFO like this.
