Car Engine Calunks!
Discussion in 'Gen 2 Prius Technical Discussion' started by Ryn01599, Jul 20, 2006.
  1. Ryn01599
    Ryn01599 Hybrid Owner for Life
    rohnert park
    In the morning (sometimes) when I turn the car on the engine turns on and idles for about 30 seconds and then shuts off with a loud calunk; nothing like it turning off at a stoplight or when I park (which is a quiet engine turning off). Is this normal?
    -Ryan Lee
    Oh BTW - Where's there a good place for window tinting in the North Bay?
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    How long have you had the car? How many miles? How loud?
  3. Ryn01599
    rohnert park
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Jul 20 2006, 01:27 PM) [snapback]289563[/snapback]</div>
    4 months - It pretty loud and happens only when I first start the car on occasions. Its like a quick sputtering
  4. marjam
    marjam Member
    220
    Silver Spring, MD
    The electric motor is supposed to pin the ICE down (and spin it up when it starts) so that there is very little clunking. But I have noticed a rough shut down every once in a while with my '04. If it is really bad I would take in in to be checked.
  5. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(Ryn01599 @ Jul 20 2006, 01:30 PM) [snapback]289566[/snapback]</div>
    New car, not quite broke-in. I'd say it's normal . . . a little disconcerting, but normal. The computer is just doing some ICE house cleaning and setting up the ICE in the proper position for a smooth start. The symptoms will go away with time . . . or you will become desensitized to it happening. I'm not sure which, but I have not heard the "Calunks" in over a year now.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The occassional rough ICE shutdown I get seems to be more likely to happen when the engine is still cold.
  7. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(cwerdna @ Jul 21 2006, 11:36 PM) [snapback]290369[/snapback]</div>
    I've also heard that because of the way the Prius emissions system works, it keeps firing the spark plugs for a short time after the last fuel has been injected - that ensures a total burn-off of all fuel in the cylinders.
    Dave
  8. etkal
    etkal New Member
    64
    <div class='quotetop'>QUOTE(Ryn01599 @ Jul 20 2006, 04:20 PM) [snapback]289554[/snapback]</div>
    Mine ('06 acquired 2006.04.01) does this as well, usually only at the end of the first warm-up cycle. It's almost like it can't decide if it really wants to shut the engine off or not, sounds similar to cars I've had that do a little "dieseling" when you turn them off.
  9. Ryn01599
    rohnert park
    <div class='quotetop'>QUOTE(DaveG @ Jul 22 2006, 01:30 AM) [snapback]290385[/snapback]</div>
    Funny - I bought my car on the same date 06 prius! :)
