Car has rough transition from battery to gas and makes noise
Discussion in 'Prius c Technical Discussion' started by Prius_C_7, Sep 2, 2019.
  1. Prius_C_7
    Prius_C_7 New Member
    southern californa
    2015 Prius c
    It's hot here in the desert and I've recently experienced the following issue after my 2015 Prius C has been parked out in the sun while I'm in the store for 30 mins or so. I start it up and turn on the A/C before I back up. The car seems to lurch a bit as it switches from battery to gas (I think that's what it's doing). This last time I noticed that the engine seems to rev up a bit. I then hear a metal noise in the engine for a few moments as I drive, and then everything settles down and is fine. The car has only 8600 miles on it so it's like new. Is this issue something I should be concerned about, or should I just continue to troubleshoot it; i.e., next time don't turn on A/C until I've backed up and ready to go, or just turn the engine off and start again. Thank you.
  2. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    That’s not normal, get it looked at before it gets worse.
    How old is the fuel?
    Prius_C_7 likes this.
  3. Prius_C_7
    southern californa
    2015 Prius c
    I don't use the car much so fuel is at least a month old. My last gas fill-up was at a cheaper gas station; I had wondered if the fuel quality might be part of the problem.
    49,490
    welcome!
    i would just keep an eye on it. check the oil level and the battery intake grille
  5. Prius_C_7
    southern californa
    2015 Prius c
    Thank you for your reply. I will definitely keep it in mind.
  6. Prius_C_7
    southern californa
    2015 Prius c
    Thank you for your input. I asked a mechanic friend to look at the engine with me, including the oil level and battery intake grille. Everything looked fine. I didn't start the car with the A/C on today and did not have the same problem. We surmised that since the intense heat causes the engine to work harder, if the car is started with the A/C on too that that might cause a momentary issue. I'll continue to monitor it.
  7. bisco
    49,490
    how hot is hot? do you park in the sun?
