Car is running, locked out, key in hand
Discussion in 'Gen 2 Prius Technical Discussion' started by ITGuy1024, Aug 20, 2010.
  1. ITGuy1024
    ITGuy1024 Junior Member
    78
    York, PA
    So I use my smart key. I had to get out of the car last night to load up something, I left it running. Well my friend pushed the black button on the door and locked them all (smart key in my pocket). I had the windows down so I could get back in but is there a way to use the smaller key to unlock the doors?
    49,433
    what do you mean is there a way? you mean other than pushing it into the lock and turning it?
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You could rap sharply on the window with the tip of the key, but I think "bisco" pretty much nailed it!!
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    :doh:
  5. bisco
    49,433
    i wish i were as brilliant as some of the people on pc and could help with more problems, but unfortunately, this is the limit of my technical ability, although i'm sure i misunderstood the question.:rolleyes:
  6. Politburo
    Politburo Active Member
    971
    208
    The system shouldn't lock in that situation...
  7. ITGuy1024
    78
    York, PA
    That lock and turn thing worked perfect! You guys rock!
    I have another question I hope you can answer...
    I am almost out of gas and I can't for the life of me find how to open the gas tank door. In my other car you just push it in and it pops open. Well I tried that and it's not working. I also tried to pull it out, but I seem to have bent it a good bit. What am I doing wrong???
  8. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    There's a release lever on the floor next to the driver's door.
  9. ITGuy1024
    78
    York, PA
  10. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    dude read the manual.
    kenoarto likes this.
  11. LeadingEdgeBoomer
    289
    29
    New Mexico
    This is a jest, right?
  12. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Whoa! One tank of gas on an '06.
    That's either very, very good FE/MPGs, or very low mileage. :rolleyes:
    I'm sure it'll come up; you can find little stick looking things on the
    wheels where you put air in to inflate them. It's pretty easy. :p
    Don't forget, you have to change the air in your tires every 5,000 miles. :D
    kenoarto and PA Prius like this.
  13. neilz
    neilz Member
    134
    Staten Island, NY
    I thought the gas tank door was for looks only. The window sticker said 'Full Tank Of Gas".:rolleyes:
  14. ITGuy1024
    78
    York, PA
    If i mis 3/4 diesel with my gas it should run better right?
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Strike three.
    PA Prius likes this.
  16. bisco
    49,433
    i knew i was being punked! dang, and i could've answered the fuel door question too.:cool:
  17. ITGuy1024
    78
    York, PA
    So this is what happens when you let your PC unlocked eh.. Awesome..
  18. bisco
    49,433
    you probably don't even own one.:mad:
  19. ITGuy1024
    78
    York, PA
    I actually do lol. Left the pc unlocked and the site must have been open. ftl..:rolleyes:
  20. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Use more force, mine pryed open easily.:cheer2: Normally we use a very large prybar!
