Car isn't ringing but bluetooth phone is
Discussion in 'Gen 2 Prius Audio and Electronics' started by voltswagon, May 24, 2004.
  1. voltswagon
    voltswagon New Member
    Cary, NC
    Shouldn't I get ringing from the car speakers when I have an incoming call? I just got a Sprint T608 and when a call is incoming the cellphone rings but I thought that ringing would come from the car speakers instead. Otherwise it works OK, I can answer the phone thru the car and have a conversation using the car speakers and mic but I would prefer that it ring through the car speakers as well. Is anyone else having this problem - or is it not a problem and I just don't understand how it works?
    Thanks!
    Bob
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    No, the car doesn't ring....I usually know I've got a call b/c the stereo mutes and I feel the phone vibrate...then I notice the ring.
  3. voltswagon
    Cary, NC
    Thanks. I guess I will need to ensure that the radio or CD is playing so it is more noticeable then!
  4. voltswagon
    Cary, NC
    One other question, how quickly does your bluetooth connection get made after starting the car? It seems somewhat slow (about a minute) to me.
  5. pino
    pino Junior Member
    38
    Now this is weird.
    My car definitely rings, unless the V600 is in "vibrate" or "silent" modes.
    Bluetooth connection takes about 15 seconds for the above mentioned phone.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The way my Nokia 3650 works is that the phone passes the ring tone through the speaker. It takes a second for this to occur. That is, unless the phone is on silent. Even then, the screen changes and the radio is interrupted.
    Also, if it's plugged into the charger, it won't vibe. If not, (i.e. it's in my pocket), it will (helps if on silent).
  7. slowpoke
    slowpoke New Member
    48
    Verizon doesn't have BlueTooth phones!:(
  8. HTMLSpinnr
    5,339
    917
    251
    5-15 secounds, depending on what mood my phone is in :-P :lol:
  9. pjdemmitt
    pjdemmitt Junior Member
    25
    Columbia, MD
    I think that the radio mutes automatically and the answer screen comes up on the center display. You can then press the left phone button on the wheel (the one with the handset lifted up) and that answers the phone. I don't think the car "rings".
    I have the same T608 on Sprint and the phone and the car work beautifully together. However, I haven't had it very long and have not gotten many calls in the car. I will pay closer attention to this. In fact, I may have my wife call me tomorrow just to check this out. I seem to remember a ring, but it could be my imagination or those bells in my head!
    Someone said the screen on this phone is small, and that is true, but if you use if mostly in the car, it's not noticeable.
    Paul
  10. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    What phone do you have, voltswagon?
    I have the T608, and I've seen the same behavior pjdemmitt explains above. The phone rings and the car does not. I'd prefer if the ring came through the speaker, but between the phone ringer and the screen displaying "Incoming Call" (sometimes with caller ID, sometimes without), I don't believe I have missed any calls.
    I have occasionally had a problem with calls being on the phone rather than the car. I'll test this further & post about it if it's an ongoing problem.
  11. williaeh22
    williaeh22 Junior Member
    Satellite Beach, FL
    On the Motorola V600, there is a menu setting called "Car Setup"
    One on the choices in that menu is "Auto answer". If you turn this feature "ON" then the Prius will answer the call automatically without a ring. If you turn it "OFF", the Prius will ring, however, you have to press the answer button (on steering wheel) to answer the call.
    Kinda counter intuitive!!
  12. Steve Goldenberg
    Steve Goldenberg New Member
    126
    Aspen, CO
    My car rings. I have a Sony T-608 on VERIZON. It works perfectly, phone book and all. I just reset the phone to leave Bluetooth on all the time. That's much easier for me and the phone battery still lasts all day. I'm just waiting for the hack to allow dialing while the car is moving as my wife generally does the driving. I did that hack for the GPS without any problem.
    My only problem (minor) is that the one touch memories get cleared when I reload the phone book. I'll have to start just adding the new numbers not simply overwritting the entire book.
  13. delrey
    delrey Member
    280
    Any idea how to get the car to ring instead of the T608?
    Thanks!
  14. toyoprius
    toyoprius New Member
    109
    Boston
    Me too, with the T608. I would guess it happens 25% of the time with my first phone call of the drive. Normally, I just hang up and try again. It always works properly then, and all subsequent calls will work through the speaker too.
  15. jimvitz
    jimvitz Junior Member
    94
    Oak Park, IL
    My connection verification time varies from just a few seconds to as long as 90 seconds and so far, there is no discernable pattern (at least to me!) to the delays based on phone position, phone battery strength, etc. Looks like a ripe area for experimentation.
  16. Steve Goldenberg
    126
    Aspen, CO
    In the Bluetooth Menu (5), select Headset Sound (6), then In Handsfree (1). I rarely have a problem although it happens after I use the Jabra which must change one of the settings. I'm going to delete the Jabra as I don't like it and I never had any problems in the car before I added the Jabra.
    P.S. My connection time is about 10 seconds or sooner if I touch the Make Call button on the stering wheel.
  17. delrey
    delrey Member
    280
    Yeah, those are my settings, and they always stay set that way.
    Nevertheless, the car *never* rings when I have an incoming call. As someone else described, the stereo mutes, the screen changes to incoming call, and the phone rings. Maybe I should try changing some other ringer settings as well ...
    I also am still having occasional problems with the first call appearing to be on the car's sound system, but actually being on the phone. I have had this happen both when making and receiving calls.
    No problems for subsequent calls though.
  18. Steve Goldenberg
    126
    Aspen, CO
    When you get an incoming call, press the option button (lower left) lightly and you'll get another menu. One of those choices is to Transfer the sound to the car. Try that.
  19. delrey
    delrey Member
    280
    Yep, that works great, thanks!
    I think that I need to just make a call when getting into the car each time (voicemail?) and then I'll be fine. I am spoiled now and don't like to take my hands off the wheel to fiddle with the phone menus :)
