Car locks/unlocks all by itself
Discussion in 'Gen 2 Prius Main Forum' started by Pennyc, Mar 18, 2023.
  1. Pennyc
    Pennyc New Member
    New Zealand
    My car locks and unlocks completely by itself. The key fob has a new battery and the car had a new 12 volt battery. I am way more than 3ft away from it. It had just done this for most of the night ( and still going). Recently had the fog lights removed (because one was cracked) for WOF requirements. Could water be making this happen? Seems worse after it has rained. But to go on all night???? Can someone please help!?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    My first thought is that there's something wrong with the switch at the driver's lock cylinder (or maybe one of the interior power lock switches- or wiring). If something glitches and commands an unlock, after a time the car will lock (normal if the ecu doesn't see a door open), but the switch is still bad so it unlocks again...
  3. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    If your car was wet, then I'd say that was the problem.
    I used to think that the best way to break into a Prius was to just spray it with a garden hose, because I noticed it would keep locking and unlocking itself whenever I washed it.
    But it turns out that proximity of the key fob was also required. So now I never wash with the key fob in my pocket.
    Soap and water running over the door handles can fool the system into thinking somebody's touching the handle.
    ....Also some Priuses will automatically lock themselves a few minutes after the key fob leaves proximity.
    BiomedO1 likes this.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,066
    547
    Tucson, AZ
    2021 Prius
    Remembering back to my Gen II SKS system, and not clearly, in addition to a sensor on the inside surface of the driver's side door pull handle there is a button on the rear hatch. The integrity of the rubber button cover may be compromised and corrosion may have ensued. The button electrical connections and mounting should be approachable from an access panel on the hatch used to change the license plate illumination bulbs. If you have a fob in your pocket while washing the car, any trickle of water over the driver's door sensor surface will actuate locking/unlocking. Maybe the sensor surface is "shorted" with some kind of detritus. Inspection with a mirror and cleaning might fix it. I never figured out if the sensor on the driver's door was capacitive or Hall Effect, or even infrared, so I'm not sure how the detection is made. The SKS system is designed to time out after a certain time period without fob detection. I noticed with my Gen II that the interior lights would come on, fob detection, at almost 30 feet. Keep your fobs further away from the vehicle or wrap them in a Faraday cage of aluminum foil.
    EDIT: Looked at some pictures of the Gen II and it appears that the same sort of pushbutton that is on the back hatch is also on the driver's side door handle. Couldn't remember if there was one. I would suspect the external controls of troubles before anything on the inside, but everything must be checked.
    #4 AzWxGuy, Mar 19, 2023
  5. BiomedO1
    BiomedO1 Senior Member
    4,125
    2,166
    SacTown, Ca
    key fob proximity auto lock is one of the adjustable options in the base settings. Depending on which level of Prius you have, some are accessible from the main display other require diagnostic tools thru the OBDII connector.
    Also check any interior door that has a lock button. I've seen soda spilled into them, causing corrosion and intermittent shorts / activation. They look fine on the surface, but when you pull them out for inspection - you'll see what I mean. Sometimes spraying contact clean down into them will take care of the problem; but once the corrosion has started - it's just a matter of time.
    Hope this helps....
  6. Markbwilson
    Markbwilson New Member
    TX
    My 2006 is doing something similar but it's definitely a fob. One of the 2 fobs goes in spells where it constantly fires to lock and then unlock - over and over and over. Evidence is the led on the fob flashing. This is as far as from 40 - 50 ft away. Removed the fob battery and the silliness stops. The second fob works perfectly. 12V is less than a year old. Just a bad fob?
