Car making noise hours after being shut off.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Denver Corrick, Jan 7, 2015.
  1. Denver Corrick
    Denver Corrick Junior Member
    North central Ohio
    About three days ago, while taking the dogs out, I go through the garage, which is not heated, and I notice the Prius is making a noise. It sounds like an electric motor running but I can not figure out where exactly the noise is coming from. It had been raining, and the car was pulled in the garage wet. About 5 minutes ago, I heard the same noise while getting the dogs in from outside. Both times I came back in the house, grabbed a FOB, and hopped in the car and put it in ready mode. I immediately shut it off, and the noise was gone. It reminds me of the sound that the car makes when you open the drivers door, which I think is the master cylinder pressurizing. It is about 7 degrees F here, but I am sure it is a little warmer in the garage. Any Idea what this may be? The car has about 33K miles on it. It gets driven everyday. Today, I got home about 4:30, and this just occurred at around 9:45. Whatever is causing the noise, I am sure will put a drain on the battery, as it definitely is an electrical motor of some sort running, which will take some power. I would hope that the power was coming from the 12 volt battery, and not the traction battery, as it usually disconnects a minute or so after the car is shut off. The car was definitely shut down when I drove it in, and every light was off on the dash when I got in to power it back up, except for the flashing lock light on the right side of the display. The wind chill here tonight is supposed to go to -25 degrees F. I am concerned about the car starting if it pulls too much power from the 12 volt battery.
    49,504
    yup. normal emissions check, believe it or not, in the rear near the gas tank. these cars are smarter than i am.:cool: it doesn't last long and shouldn't use much of your 12 volt.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    This is talked about in the manual as well.
  4. Mendel Leisk
    38,733
    First time I heard such noises, I'd just jacked up the rear and was underneath for a look see: freaked me right out. ;)
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    It is the sound of a pump performing a fuel evaporation leakage check.
  6. GregP507
    GregP507 Senior Member
    3,002
    480
    Love the tech, trust the tech, because it easier than trying to figure the damned stuff out.
