Car not picking up FOB
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tommymommy, Jan 4, 2022.
  1. tommymommy
    tommymommy Member
    110
    So got in my 2007 Prius this morning and tossed my keys in the cup holder like always. The car is saying the key is not available. However, if I plug it in the dash it works just fine. This is something new to me. The doors lock and unlock just fine with the key fob but I'm not sure why the car is not picking it up in order to start.
  2. Tombukt2
    Tombukt2 Senior Member
    9,075
    1,574
    Durham NC
    Srs button under Steer wheel pushed
    49,433
    check the fob and 12v batteries
  4. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    fob battery is my guess
  5. PriusCamper
    PriusCamper Senior Member
    11,092
    4,514
    Pacific Northwest, USA
    I had this happen when I tried to add a new FOB to the system... Something went wrong and FOB wasn't able to be added and I lost that function and have had to plug the FOB into the dash ever since.
  6. tommymommy
    tommymommy Member
    110
    Changed the key fob battery and it worked for one day.
    So, was able to perform a check on the battery and it was bouncing me between 10.8 and 11. So obviously it was time to change that, even though it's only 2 years old. Sadly, I can't remember where I bought it from, since I take care of both of our Priuses, and cannot find a receipt for it in the file for that vehicle. Ended up changing out the 12 volt battery. Key fob still didn't work. Changed out the key fob battery a second time and as of yesterday, knock on wood, all is working.
  7. Another
    1,802
    511
    Naples, Florida
    The manufacturing date which is the fall back to the receipt-less install date is usually on the battery body. Take it to a dealer for that make and model of 12v battery. If it’s two years or so it’s likely it’s a free replacement. Then again if it was sitting on the dealers shelf for three years and you got stuck with it, you’re likely SooL.
  8. tommymommy
    tommymommy Member
    110
    I'm SOL. Oh well...its only money. It's still disappointing because the battery is only 2 years old. I can't for the life of me remember where the heck I got it from and I don't find anything in my email but I would have been the one that installed it.
  9. bisco
    49,433
    it is good practice to check new battery voltages before installing. if the fob battery is 3.3v, i would suspect a bad connection in the fob if it happened again.
  10. Another
    1,802
    511
    Naples, Florida
    What is the brand and model?
    Do you have a photo of the label?
