Car not running, and need some advice.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jfountain2, May 21, 2015.
  1. jfountain2
    jfountain2 Junior Member
    40
    Pima, Arizona
    On Tuesday night I was driving home and my lights went off. Just my headlights, the high beams worked, brake lights and parking lights. I checked the fuse it was ok. When i restarted the car everything was on. The check hybrid cam on as well. I made some calls and they sai I should be able to drive it to a store. The car started and quickly completely died. All the light on the dash are on. I call the closest service center and they sai, they thought it was my hybrid battery. I have not been able to attach an obd2 for a sensor read. My car is a 2010 with 120,000 miles on it. I just had it serviced on may 9 and I have put 1100 miles on it sonce. I work on the San Carlos Indian Reservation as a special education teacher and drive 100 miles a day round trip. My car has been great to me until now. When i looked in then engine compartment, the oil was over filled and the coolants were all very low. I live in arizona. There has been nothing wrong with the car ever. I bought it in Vermont, brand new. They told the battery had 10 years or 150,000 miles. Now toyota is saying because I live in arizona, they wont honor the warranty i was sold in vermont. I also do not know if that is the problem. I live 130 miles from the closest service center. The tow even after triple aaa is 150 bucks. I have two more day of teaching on the san carlos reservation and then it will be summerbreak. So, i have a ride to work, and then can focus on this. I really want a plan for how to make sure the battery is the problem. They gave me a price of 3250.
  2. Mendel Leisk
    38,718
    Don't be too quick to suspect the hybrid battery, seems like a lot of strange electrical behaviours. Any warning lights on? So far nobody's looked at it?
  3. jfountain2
    40
    Pima, Arizona
    Triangle light, hybrid systm warning, brake, battery, all the signals on the right side of the panel except low tire pressure
    Here are pics
    It does say ready
    All of the electrical stuff didnt happen until i opened the fuse box....and change the headlight fuse..
    Would an obd ii scan work?
    #3 jfountain2, May 21, 2015
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Check the 12V battery. If it's the original it's time to replace, and a weak one can cause all sorts of "false warnings".
    HaroldW likes this.
  5. JC91006
    16,482
    8,399
    Have you done the recall on the inverter? That is more likely the issue
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Double check your fuses in the the fuse box that you may have disturbed.
    If everything looks good in the fuse box, I 2nd the inverter being the likely cause.
    #6 IMkenNY, May 21, 2015
  7. bisco
    49,469
    if you're in springfield ma, you should be covered.
  8. jfountain2
    40
    Pima, Arizona
    Hi. I don't live in springfield Ma anymore.. Pima, Arizona.
    There was an inverter recall
  9. bisco
    49,469
    there was.
  10. jfountain2
    40
    Pima, Arizona
    I have some obd2 codes c1259 hybrid cotrol c1310 u0100 three times. It looks like the car has stopped telling the engine to run.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    First thing to check is 12V. This was already mentioned. If it does not show 12v or better then the PC 's are having problems sending info on what the car requires to run. check with a multi meter.H
  12. jfountain2
    40
    Pima, Arizona
    I mess up the fuses and ... Weel there is one code u0100 no connection to the engine.. Lost communication with engine controla module a
  13. jfountain2
    40
    Pima, Arizona
    In my haste tuesday night, i piled the main fuse efi or fuel injection. It started with the headlights not being on. The headlights are not on. I need to clear the codes so the engine will start
  14. Den49
    Den49 Member
    498
    268
    Maryland
    Suggest the following steps:
    1. Check that the 12V battery is fully charged; if not, charge it or replace it if it is the original battery or fails a battery test.
    2. Try to clear the codes.
    3. Investigate the possible causes for U0100 code.
    - Faulty Engine Control Module (ECM)
    - ECM harness is open or shorted
    - ECM circuit poor electrical connection
    Read more: http://engine-codes.com/u0100.html#ixzz3asEHMgPx
    4. Repair/replace any failed wiring or components. If no apparent failure, disconnect, clean and reconnect ECM wiring connector.
    5. If none of this works, it is time to have the car towed to the dealer for professional diagnostic. Hopefully, it is not the HV battery.
    #14 Den49, May 22, 2015
  15. jfountain2
    40
    Pima, Arizona
    The battery is good. Recharged. The check hybrid is back on... C1259 as well.
  16. jfountain2
    40
    Pima, Arizona
    Can someone skyp me through this?
    Joseph.fountain98
  17. jfountain2
    40
    Pima, Arizona
    The hybrid battery is fully charged, the 12 v. Is fully charged. I have two codes c1259 and u0100
  18. bisco
    49,469
    not sure those codes are correct, are you using mini vci?
  19. jfountain2
    40
    Pima, Arizona
    Bosch obd 1200
  20. bisco
    49,469
    not all readers are prius specific.
