Car not starting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Suz you, Feb 1, 2022.
  1. Suz you
    Suz you New Member
    Michigan
    Hi I have a 2010 Prius gen 4, it has 150,000 miles on it, new battery two years ago, it been well maintained. The pass week when you go out it’s decided to not start unless it’s jumped, I had it checked out the batteries are good, what could be causing this? It’s not showing any codes that are bad. Any ideas? The help is greatly appreciated.
    Thank you
    Susanne
  2. ASRDogman
    ASRDogman Senior Member
    7,798
    3,978
    "I had it checked out"
    How was it checked? If it starts when it's jumped, you can suspect the 12v battery.
    Did you get a new 12v battery or Hybrid battery 2 years ago?
    A 2 year old battery "should" be good, but it will depend on the brand, and how much
    you drive it. If the car sits a lot and you only drive a few miles a week, it won't be enough
    to keep it charged up.
    If you have an AGM battery charger you should put that on the battery overnight, if possible,
    so it will have a good charge.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Need a load test
