  1. Prius Fleet Owner
    Prius Fleet Owner Junior Member
    22
    Plymouth
    Active
    Hello all.
    I am unable to get access into my 2nd generation Prius.
    Basically, the fob is not unlocking the doors and I have also tried the key to open the doors but not working.
    All doors will not open so I have quite the predicament.
    Ideas???
  2. JC91006
    16,482
    8,397
    Try to wiggle the key while you're twisting it to turn. It'll eventually break free
  3. Prius Fleet Owner
    22
    Plymouth
    Active
    Not sure what you mean. Never used the key before to open so not sure how much it has to be turned to unlock the doors but managed to turn it around 90 degrees but door not opening. I will try that again tomorrow as the car is abandoned in a public car park at the moment.
  4. JC91006
    16,482
    8,397
    Try turning it the other direction 90 degrees, to unlock
  5. Prius Fleet Owner
    22
    Plymouth
    Active
  6. Prius Fleet Owner
    22
    Plymouth
    Active
    Got it open in the end. The mechanic managed it with the key.
    Could not manage it myself though. Just did not want to open.
    Battery had run flat due to driver leaving sidelights on hence immobilizer not working.
  7. bisco
    49,455
    toyota should recommend people learn how to use the key when not needed, and exercise the lock occasionally.
  8. Prius Fleet Owner
    22
    Plymouth
    Active
    Agree. Don't think there are any notes in the owner's manual.
    My presumption is the key has hardly been used from new if at all.
  9. bisco
    49,455
    unfortunately, this happens all too often, nd if you're stranded somewhere, it could be a big issue.
  10. edspecR
    edspecR Member
    136
    94
    Berkeley
    my current predicament. I disconnected the 12volt for an 8 week trip overseas, and low and behold, my mechanical key does nothing to the driver side door of my prius C. turns 90* both clockwise and counterclockwise. I've jiggled and jangled, and just about every other sequence under the sun to no avail.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    Just another Prius Oddity!! (my list is always growing) Can't wait to read the answers for this one. Is the Prius door lock somehow different than the millions of other mechanical door locks out there?! That simple Corolla is looking better and better... :LOL:
  12. dolj
    dolj Senior Member
    7,648
    3,860
    Wellington, New Zealand
    As your car is a Prius c, it is probably best to start your own thread on a suitable forum over in the Prius c section, rather than tacking onto a Gen 2 thread. The folks over there have more knowledge and experience with that model Prius, so you will get more focused help with your problem.
    As for the Gen 2, and already covered by this thread (and many others), with the remote lock/unlock or SKS system, the physical lock does not get much of a workout. It helps to use a bit of dry lube once a year when you do your routine maintenance and exercise the physical lock. Not really much of a mystery.
    #12 dolj, Aug 12, 2018
  13. dolj
    dolj Senior Member
    7,648
    3,860
    Probably has no relevance to your 2016 Gen 4, but thanks for popping into the Gen 2 forums.
  14. Starship16
    1,348
    1,453
    Beach Christmas
    I "pop" all over. I am curious about all things Prius. All generations. :) And I would sure like to know WHY these Prius doorlocks are so weird. You mean to tell me, that my mechanical key may not work just when I need it most???
    #14 Starship16, Aug 12, 2018
  15. dolj
    dolj Senior Member
    7,648
    3,860
    Can't speak for the Gen 4, but on the Gen 2, there is nothing weird about these locks.
    If you don't maintain it, yes it may not work just when you need it most. Maintain it and exercise it once in a while, no problems at all.
    Starship16 and jerrymildred like this.
  16. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    +1 @dolj. I've had Gen 2 locks apart. They are just like the ones in my previous power lock vehicle. Like any key mechanism, if you let it sit in the weather for 10 years and never use it or lubricate it, you should not be surprised if it's a little crusty inside.
    Starship16 likes this.
  17. Starship16
    1,348
    1,453
    Beach Christmas
    Understood. I do use the key occasionally.
    I thought the poster was referring to some type of electric malfunction, because he removed the negative terminal of the battery for a few weeks. But that shouldn't affect the manual key use.
  18. dolj
    dolj Senior Member
    7,648
    3,860
    He may well have been. But the Prius c is not a Gen 2 Prius, so us Gen 2 folk can’t really comment.
    One of the reasons this site is split into sections for each model, is that information about one model is not necessarily interchangeable with another (or generation, even) and is the point of my advice to post in the correct section of the site.
  19. edspecR
    edspecR Member
    136
    94
    Berkeley
    I don't disagree with you, but i figured a post from someone else with this problem would be more relevant and time-saving than starting a new post in a forum where others with a similar problem might not "pop" into. its a door lock, not really anything specific to a gen 2 3 4 or C. but maybe specific to priuses or toyota as a whole.
    i bank on the notion that when i need an answer right this second, I'm better off searching vs posting a new thread and hoping someone answer, particularly without searching if others had a similar issue.
    fwiw, i took apart the entire front end of the car from the outside to unlatch the hood, found no jump terminal, hooked up jumper cables to a positive lead anyway but realized a disconnected battery must mean an open circuit somewhere (so much for parallel circuits?) so that didn't do anything. ended up swallowing my pride, called AAA and they unlocked my car with their standard procedure (air bag + stick). took a few hours to disassemble to pop the hood... after AAA, car was good to go after 10 mins. :s
    still unsure why my key doesn't unlock my car, will have to try with the battery hooked up now. otherwise I'll check the linkages and actuator.
    although this was for a C, I dont see why it wouldn't be relevant for other priuses. God forbid toyota use the same parts for different cars! :p
  20. jerrymildred
    11,508
    14,110
    Tampa, FL
    I re-read your previous post (#10) to refresh my memory. I've had several doors apart that had power locks. Every one of them had a mechanical connection between the key operated lock and the actual locking mechanism. When you turn the key, a it pushes or pulls a rod or cable that moves the lock open or closed. It does not use the linear actuator (electric motor) so that if it fails, you have a mechanical backup. If you can turn the key 90° in either direction, I'd be looking inside the door to see what fell apart in there.
    edspecR likes this.
