Car parked in garage, how long will battery.....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chrisky, Aug 1, 2008.
  1. chrisky
    chrisky Junior Member
    Burlington,ON. Canada
    2018 Prius Prime
    We usually go down south to avoid our winters. We will be leaving our car in our garage for approximately 2 months. With our other non-hybrid car, we usually had our friend start up the car every 2 weeks or so. So my question is, will the battery stay charged for that length of time or do I have to instruct our friend on starting the car and possibly driving it around the block to charge the battery.
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    If you turn off the Smart Key System (SKS; button under the steering wheel that says "Key"), you should have no problem leaving it for 2 weeks at a time (or longer, probably). In reality, you could probably leave the SKS on, but that's the primary battery drain, so turning it off means even fewer battery troubles. With the SKS off, every two weeks should *easily* be often enough; you could probably even stretch it to once a month, if you needed to.
    Of course, with the SKS off, whoever drives it for you will have to push the button on the remote to unlock it and have to physically insert the key into the slot in the dash.
  3. Patrick Wong
    18,200
    6,493
    It is likely that the 12V auxiliary battery will discharge after 2 months. You can either have your friend make the car READY for 30 minutes every two weeks (not necessary to actually drive the car) or else disconnect the 12V battery before you leave on your trip.
    One way to disconnect the battery is to open the hood and find the main relay/fuse box near the inverter. Open the lid by pressing hard on the latch at the front of the lid. Find the dedicated jumpstart terminal covered by the red cover, lift up the cover, then remove the nut that is revealed (need 10 mm socket and socket wrench).
    Lift off the wire terminal that the nut had secured. Replace the nut. Lower the red cover. Put the wire terminal on top of the red cover. Now the vehicle should be totally powered down.
    Replace the relay box lid and lower the hood. Lock the doors manually, and the car is ready for storage.
  4. chrisky
    2018 Prius Prime
    Thanks for the answers. We'll be going away for 3 weeks initially, so will turn off the SKS and see how that works.
  5. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    In 2006 I deployed to Guam for 4 months. During that time I left my battery negative cable disconnected. When I returned, the 12V battery still had a full charge, and the traction battery was unchanged at a full compliment of the blue bars. I even got 49 MPG on that tank.
    I like Mr. Wong's method of disconnecting the underhood connection. Popping the rear hatch with no power is a slight challenge.
  6. chrisky
    2018 Prius Prime
    Thanks. I'm not the most mechanically inclined person. But that may be the way to go when we're away for 2 months.
