Car powered off and won't turn back on. Was stranded on the side of the road at midnight.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlohaSpirit, Aug 12, 2018.
  1. AlohaSpirit
    AlohaSpirit Junior Member
    67
    23
    Hawaii
    So I left for work at 9pm, got 2 stoplights away and as the light turned green on the 3rd light, I lifted my foot off the brake, the car moved forward and then turned itself off. Luckily I was able to coast to the shoulder...
    I tried to jump it using the fuse box points under the hood and when that didn't work tried to jump direct from the 12v in the back. That didn't work either. All I get is the red car/key icon on the dash and the fob light will blink red once when inserted. I can hear that little whirling coolant pump from behind the dash when I try though.
    So I finally located a tow at 2am and got it back to my place. Next day I went and got an optima battery.
    Installed battery and still nothing. The dash or screen doesn't turn on and I have tried both remote start and placing the key in the slot. Have also tried it with both my key fobs. I'm kinda stumped and I have a long day at work tomorrow and wish the battery was the fix.
    Here are some details.
    2007 prius w 95k miles
    Dash or screen doesn't turn on when power button pressed.
    Hybrid battery was charging decently and I was getting 45mpg+
    Red car/key icon on the dash with start attempt and the fob light will blink red once when inserted. Whirling coolant pump sound.
    Original battery was 3 yes old. Replaced with yellow Optima.
    Headlights, all domelights and open door chime still work and turn on when fob is present. Also able to open and close doors with fob.
    I did have an old mp3 player plugged into the cig lighter in the middle console (so I had thought I had inadvertently drained the 12v battery)
    You guys really helped the last time.
    Maybe someone can chime in with a link or a fix.
    Aloha!
    48,963
    start with all the major fuses and the inverter pump.
  3. JC91006
    16,470
    8,383
    Most likely blown AM2 fuse, from a shorted inverter pump.
    Disconnect the pump and replace the fuse. If the car turns on, then that's your problem. Look at picture attached, AM2 fuse location and pump disconnect. Screenshot_2018-06-16-13-14-02.jpeg
    AlohaSpirit likes this.
  4. AlohaSpirit
    67
    23
    Hawaii
    Thanks for the quick reply.
    I went and took a look.
    Is there a fuse in there?
    (Looking up AM2 fuse now)
    Also no red triangle. And no smoke.
  5. Paul Schenck
    Paul Schenck Active Member
    522
    306
    Fresno, California
    You’ve gots blown fuse! 13 or 14 or 16
    It’s never happened to me but something shorted
    Replacing battery reset the code
    iPhone ?
  6. JC91006
    16,470
    8,383
    The fuse is in the fuse box pictured, next to the hand
  7. AlohaSpirit
    67
    23
    Hawaii
    Ok... That worked! You guys (y)
    Changed the second 15a fuse on the right
    Can't believe a $1 fuse cost me $500 for tow and battery :cry:
    Now I have to get extra fuses.
    I have owned it a while and this is the first time this happened. Should I be concerned?
    Least now I can work on the radiator on my wife's car :rolleyes:
  8. bisco
    48,963
    you need a new inverter pump, not more fuses.
    kenoarto, edthefox5 and Raytheeagle like this.
  9. JC91006
    16,470
    8,383
    You need to replace the inverter pump. It would be free if you didn't do the recall at the dealer.
    You can only drive a short distance with the inverter pump disconnected. So don't drive far
    The 12v is almost never the issue when the car dies while driving. Not sure why so many people blindly replace it
    Mendel Leisk and Raytheeagle like this.
  10. AlohaSpirit
    67
    23
    Hawaii
    I'll try contact my local Servco but they take forever. Its also 20 miles away. May look into replacing it myself.
    So I can't drive it huh... and I should leave it unplugged?
    And this is what I need to replace?
  11. JC91006
    16,470
    8,383
    You can drive it, but short distances. I Think you can do 20 miles in the morning without traffic. If you plug it back, the fuse will blow again
    Yes the pictured item needs to be replaced. Lots of YouTube videos on this, not very hard to do
  12. AlohaSpirit
    67
    23
    Hawaii
    Ok. Will look into it.
    And did a search when car died. Battery came up but fuse didnt... so went with it
  13. JC91006
    16,470
    8,383
    Unfortunately these forums get responses from many people that are trying to help. So sometimes the advice may not be correct
    DLC82SV likes this.
  14. AlohaSpirit
    67
    23
    Hawaii
    It's all good. You guys are great. Thanks to everyone that posted.
    I also turned the car on and opened the reservoir. No coolant turbulence... so I guess that's that.
    Looked up the replacement. Didn't seem too bad. But they all remove the headlight while someone said you don't have too... so searching for that.
  15. JC91006
    16,470
    8,383
    It's shorted, that's why the fuse blew. You won't get turbulence now because you've disconnected it
    Raytheeagle likes this.
  16. bobodaclown
    bobodaclown Member
    214
    71
    Just had to change mine. Remove the headlight, it's much easier, only adds about 10 minutes. It's harder to get the bolt that is mounted sideways that needs to be removed to remove the actual pump mount. Think the only tools are a 10mm 12mm, pliers and screwdriver.
    Z981 ?
  17. AlohaSpirit
    67
    23
    Hawaii
    i put a new fuse in and plugged it back in. Turned car on and no turbulence.
    Ok thanks. Z981?
  18. bisco
    48,963
    phone type
    bobodaclown likes this.
  19. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    It is much easier with the headlight removed. Easy access to the area around the pump. Lotsvof places to scrap yourself or get cut. Your hands will thank you.
  20. Paul Schenck
    522
    306
    Fresno, California
    Removing the headlight works it takes a few minutes. I had to replace one in a rush so I removed the inverter-mount 14mm x2 then long extension and 10mm. I sheared off the stud so I-only use two bolts to hold it now.
    The trick is finessing it around the corner up and out in front by the radiator.
    iPhone ?
