Car Purchased w/ No TPWS
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Benrrrr, Aug 22, 2019.
  1. Benrrrr
    Benrrrr New Member
    NW
    2015 Prius c
    Hey folks,
    So I took my Prius C in for maintenance today (tpws light has been on since purchase several months ago). Technician was shocked to find that none of my tires had the sensors installed. He took a look at the vehicles service records and found they’d been removed from the vehicle during a tire changeover. Because I bought the car without the monitoring system in place, they could not have the parts installed under warranty. The folks at Toyota said they’d never seen a case like this before.
    As this was a Certified Pre-Owned purchase, should I expect the dealership I bought the car from to re-install the TPWS?
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Yes - but good luck. If it's really "noted" on your service records that may be the only way it'll be corrected at no charge to you.
    Benrrrr likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    You need to determine if this is specifically spelled out in the legaleze of their "Certified Pre-Owned Purchase" program. TPMS is require on all new cars of this class sold in the US after Sept 1, 2007. Not sure how the law effects used car sales.
    Benrrrr likes this.
  4. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Just for your information, it is TPMS(Tire Pressure Monitoring System), not TPWS whatever they mean by that. If the TPMS light was on when you purchased the car and it was a Certified Pre-Owned sold by a Toyota dealer, then yes, I would press hard for them to correct the issue. If the vehicle did not come from a Toyota dealer, then you may have to look close to your purchase agreement to see if there is any statement regarding to "as is" condition.
    In any case, it is not unusual an owner of the car to remove TPMS especially if one needs separate set of rims with winter tires. If you have to pay for the installation of new TPMS sensors, do not take your car to a dealer. They will charge you arms and legs for simple devices and reset. Instead take your car to a local tire shop. They can install them much cheaper, I would say less than $200 installed (parts and labor). To save even more, you could wait until you need a set of new tires, then installation cost is null as any tire shop will include that process with normal tire mounting. If I was in your boat and I can not get the dealer to pay for the installation, I would just buy one of external TPMS for ~$40 on Amazon and forget about dumb internal TPMS that came with the car. Of course, if you are OK, you can just forget about whole system and check the tire pressure yourself more frequently. That would be the cheapest. Good luck, and let us know how it goes with the dealer.
    #4 Salamander_King, Aug 23, 2019
    dubit, Benrrrr and jb in NE like this.
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Did you not question this at purchase? TPMS light ON is not normal.
    I would first take it back the dealer from whom you purchased it as CPO and request/demand that they fix it under their warranty. If they won’t, then advice from Salamander_King is sound. For $200, I would buy a good $30 tire gage, pocket the change and check my tire pressures manually.
    Benrrrr likes this.
  6. Mendel Leisk
    38,732
    Someone put on new tires and had the four TPMS sensors in the rims removed, used regular valves. No big deal. Except, assuming the sensors are long gone, you need to pay for new sensors and the install. Or live with it.
    Still, since you bought CPO, maybe you can get reimbursed by the dealership. It doesn't say much for CPO if they didn't even notice the light.
    FWIW, every winter we drive on alternate snow tires on rims, no sensors.
