Car quit while driving
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AmyV, Jan 26, 2026 at 5:26 PM.
  1. AmyV
    AmyV New Member
    Yesterday
    Hello- we have a 2012 Prius V with approx. 158,000 that has been very reliable until last week.
    After a series of 20 minute trips all day the car was parked for 1.5 hours. I left for another errand and drove for about 4 minutes. After stopping at a stop sign, I pulled out and gave more throttle to get up to the 40 mph speed limit. The car accelerated but didn't shift into 2nd gear, I slowly lost power and pulled off to the side of the road. I then heard a clunk.
    I realized we were in trouble and I hoped I could limp back home. I turned car around and was able to drive another minute or two, I believe in EV mode but with minimum power. The check engine light came on and then the car lost all ability to move forward.
    We rented a code reader and the code displayed is P3190. We haven't been able to decipher that code and we're hoping to have more information before we bring to a mechanic or the Toyota dealer.
    Anyone else have this experience? Or can you give more info on that code. Any thoughts appreciated.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,289
    6,436
    Texas Hill Country
    Basically it means a typical engine problem. One of the most obvious is running out of gas or a bad fuel pump (rare). Have it diagnosed soon.
    See video
    BiomedO1 likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    3,880
    2,027
    SacTown, Ca
    Yep; there's a problem with your gasoline engine - won't run.
    Usually when your engine is warm and you have a decent charge on the traction battery, the engine will turn-OFF when you stop at a stop sign. When you take-off again, the engine fires-up and you move. That error code is saying the engine isn't starting or running on it's own. Continuous attempts to spin the motor will draw down the traction battery, requiring a dealership recharge of that traction battery. Judging from the age of the battery; a deep draw-down could also damage it - push it over the edge.
    #3 BiomedO1, Jan 26, 2026 at 10:04 PM
  4. VelvetFoot
    VelvetFoot Active Member
    936
    337
    New York State
    2026 Prius
    Thinking outside of the box. Could it be water in the gas and cold temperatures? Maybe relocate the car to a warm place? If possible.
