Car randomly locks itself
Discussion in 'Prime Main Forum (2017-2022)' started by IABoy987, Mar 7, 2024.
  1. IABoy987
    IABoy987 Member
    184
    76
    Iowa
    2018 Prius Prime
    Every once in a great while when we get ready to leave the house. we find the car has locked the doors. Doors open when we pull the handle, but we can't find a reason for why it does this. I thought maybe somehow one of our fob buttons got pressed and locked the doors.
    Not a earth shaking problem, just curious if anyone else has their car lock up for no apparent reason.
  2. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    If you've ever spilled some sugary drink into the door handle control panel - it could cause an intermittent short.
    IABoy987 likes this.
  3. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    Yep, it''s happened to me a few times too, Every once in a while I get the sense the car is haunted or something. Seriously, I do try my best to understand what the car is thinking, but sometimes it's just beyond me. I need it and a few of the other strange things it's done, to happen at least a few more times before I can even begin to try an understand why it does some of the weirder things I've noticed it do in the past.
  4. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Not sure if this answers your question, but the car will re-lock the doors if you unlock them with the fob and then not open any door. There's some timeout before this occurs, but it's a safety feature to make sure you don't unlock your car accidentally and then forget about it and leave your car unlocked.
  5. sylvaing
    sylvaing Senior Member
    1,045
    429
    And you can adjust that timeout. By default, it's 30 seconds. I've increased it to its maximum (two minutes) using Carista. Or pay the stealership to adjust it for you.
  6. Mendel Leisk
    38,726
    Might be this. At least once I've triggered the panic alarm, when our '10 is in the garage.
  7. vvillovv
    3,664
    1,293
    NY
    It happened to me last week while washing the car with the fob in my pocket. That one wasn't so mysterious. Kinda on the level of butt dialing the phone.
  8. iskoos
    iskoos Active Member
    401
    246
    Orlando, FL
    Interesting, does it do it when the FOB is in the range?
  9. iskoos
    401
    246
    Orlando, FL
    That or if you are washing your car with the key fob is nearby for example. That water triggers the SKS. But this is not what the OP is talking about.
