Car Readiness to Return to Commuting
Discussion in 'Gen 2 Prius Main Forum' started by Marila, Jun 10, 2021.
  1. Marila
    Marila Junior Member
    North Carolina
    Hi all,
    After over a year of mostly short trips I am going to commute again. I have 191k miles on my car and have mostly only had oil and battery changes since the pandemic started. I haven't been going to the dealer for the mileage related check-ups. I need to fix a tire pressure sensor and I'd like to get my headlights buffed because they are foggy now. What other things should I be looking to have done?
    My car is a 2007.
    Thanks!
    49,500
    welcome!
    have you done all the recommended maintenance through 190k?
    if not, at what mileage did you stop doing them?
    Marila likes this.
  3. 120m256
    120m256 New Member
    17
    Arizona
    @Marila new headlights are about $100 on ebay. Sometimes the old ones don't buff out all that well. I would try that first though.
    Just for general maintenance, I would recommend changing the coolant, transmission oil, and sparkplugs if they haven't been done in the last couple years/50k+ miles.
    Also, if your tires are over 5 years old, or dry rotted/cracked, you may want to get a new set. I just got a set of Ohtsu FP7000 tires, made by Falken. They were only $46 each, and ride great. I had them on another car too.
    Marila likes this.
    49,500
    how are they for mpg's?
  5. bisco
    49,500
    your welcome!:)
  6. Marila
    North Carolina
    I don’t know. I will have to find out. It’s been a while.
  7. Marila
    North Carolina
    I have definitely not replaced those things in the last couple of years. Will have to look at mileage. I had my tires checked at Discount Tire a couple of weeks ago and they aren’t rotting. I did have to replace one of my sensors and the guy warned me my tread was getting close to replacing but not yet. I did wonder how long before it rots. This is helpful.
  8. Marila
    North Carolina
    Where did you get your tires? And are they good for mileage and a smooth ride?
  9. 120m256
    120m256 New Member
    17
    Arizona
    I got the tires from S&S Tire in Avondale, AZ, but installed at Sinoloa Tire in Phoenix.
    They are good for the money. Didn't notice any increase or decrease in mpg. Rode smooth, and pretty quiet.
