Car recognizes me when I walk by after I locked it
Discussion in 'Prime Main Forum (2017-2022)' started by bamike, Jan 9, 2019.
  1. bamike
    bamike Junior Member
    59
    32
    DC
    2018 Prius Prime
    Does anyone know how to disengage this feature. I’ve got the key in my pocket and the car is locked, but when I walk by it turns on the interior lights until I get farther away from it. I don’t want the car to do anything without me touching the door handle or pressing a button on the fob.
  2. Tideland Prius
    16,128
    Slide the position of the interior light switch to OFF instead of DOOR.
    WilDavis likes this.
  3. ChapmanF
    15,480
    That will, of course, prevent the dome light from coming on even when you really do open the door.
    Using Techstream, you can set the customizable feature for the car not to respond with the interior lights when you walk by. It was one of the first settings I changed on mine. Carista can probably change it too.
    Tideland Prius likes this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    https://www.toyota.com/t3Portal/document/om-s/OM47C17U/pdf/OM47C17U.pdf
    is your owners manual, on page 744, it shows that to turn off illumination option "Operation when you approach the vehicle with the electronic key on your person" is not possible from the center screen. Either the dealer or some one with a ODBII programmer and the right code would need to do that.
    If you decide that it annoys you enough to have the dealer do that, I would consider every other customization item before hand, so you only pay once.
  5. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    I think you can change it with Carista.
  6. bamike
    59
    32
    DC
    2018 Prius Prime
    Thank you this is exactly the info I needed. It doesn’t bother me enough to pay to have it changed, but it’s crazy that we can’t change this setting ourselves.
  7. bisco
    49,397
    maybe on prime, it's available in the menu
  8. Hayman66
    Hayman66 Member
    92
    117
    I kinda like this feature. I feel like my car is saying Hi when i get close. :ROFLMAO:
  9. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    The manual says it's under "Settings that can be changed by your Toyota dealer". In other words not in a menu.
  10. Offline
    Offline Active Member
    637
    230
    Lenexa, Kansas
    I think it's a great feature. I'm curious about why this is considered to be a problem?
    #10 Offline, Jan 10, 2019
    WilDavis and Bob Comer like this.
  11. bisco
    49,397
    if the o/p only knew all the things the car was doing when they aren't around :sneaky:
    huskers, RobH and jerrymildred like this.
  12. bamike
    59
    32
    DC
    2018 Prius Prime
    It’s a problem because the car is wasting battery constantly scanning to see if your key fob is getting close. It’s also putting you at risk for a robbery by making it clear you’re approaching your vehicle and which vehicle is yours. I’m going to have it reprogrammed by my dealer free of charge.
  13. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Just turn off the key fob battery. Only takes a second.
    bamike likes this.
  14. ChapmanF
    15,480
    Turning off the "welcome light" feature will not reduce battery use, because the rest of the smart-key system will still be operating (to let you open the door by touching its handle, etc.). But it will address your security-risk concern.
    If you want to save battery, turn off the smart-key features entirely. Then you also won't have the touch-to-unlock door handles (you'll have to unlock by pressing the fob button, or turning the key) or simple push-to-start (will have to hold fob next to power button to start). That will stop the constant scanning and reduce the drain on the aux battery.
    Caveat: I'm speaking from Gen 3 knowledge; somebody correct me if those details have changed for Gen 4.
  15. RRxing
    2,519
    1,790
    NEPA
    Turning off the key fob turns off all of the features you mentioned...
  16. ChapmanF
    15,480
    From that owner's manual page 178 that you posted, it's not clear whether that feature is for extending the life of the battery in the fob, or the battery in the car. It is sort of written to sound like the former, but it doesn't come right out and say.
    Just turning the fob off would certainly save the fob battery, sure, but would not reduce drain on the car battery, because the car will still be looking for a fob.
    To preserve the car battery, you need to tell the car to stop looking for fobs.
    In Gen 2 you could do that with a single button under the dash, and in Gen 3 you have to do it with a ten-step dance pressing one of the fob buttons and the driver's door-open switch.
    I don't know how it's done in Gen 4 ... possibly that is what that page 178 procedure is doing, and they've just described it oddly.
    If you have two fobs, and you try following that procedure with one of them to turn it off, do the car's proximity features still work with the other fob, or not?
    Andyprius1 likes this.
  17. bisco
    49,397
    based on his premise, o/p is doing the right thing
  18. ChapmanF
    15,480
    Well, o/p mentioned two concerns (in #12), and what o/p seems to be doing about it (in #6) will address one of them but not the other. But the only way to address both would be to turn off even more functionality, so it's o/p's call whether that's desirable or not.
    In that sense, whatever o/p decides will be the right thing....
  19. bisco
    49,397
    agreed. seems like the paranoia should take precedence
  20. RRxing
    2,519
    1,790
    NEPA
    It appears to just preserve the fob battery, but it prevents the interior lights from coming on when in close proximity, and won't let you unlock the door(s) by touching the door handle (I know this is how it works), which is what the OP seems to desire.
    I would assume (I know, I know...) that the car is still searching for a fob signal, which would of course cause a VERY minor drain on the 12V battery, but if you (or the dealer) disable this function you would have to use the mechanical key every time to unlock the door and (perhaps) prevent the car from starting, even if the fob is used at the power switch.
    In any case, I believe that the car stops searching for the fob signal after a set period of time (a couple of hours?). I think the Gen III did the same thing.
