car sags to the right when making a left hand turn
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eeway, Jul 11, 2016.
Tags:
  1. eeway
    eeway Junior Member
    The rear sags when I make a left hand turn. Not certain if it is a bad shock or something else. Also, the rear dropped twice when I was filling the tank last week. Any information is appreciated before I take it in for service. thanks
    49,469
    odd, how many miles on her? any accidents?
  3. JC91006
    16,482
    8,399
    I don't know what you'll achieve posting in a forum, it's obvious you have a suspension problem
  4. solrunner
    solrunner Member
    114
    37
    Reston, VA
    If you push down on the rear right corner, anything unusual happen? Do it on all four corners and compare.
    Each corner should bounce once or twice and then stop. If it bounces more than that the shocks/struts are worn out and should be replaced.
    How many miles on the odometer?
  5. bisco
    49,469
    i can't imagine the rear dropping whilst filling the tank. what are we talking, a hundred pounds max?
  6. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Definitely sounds like a suspension problem. Springs....possibly struts as well
