car shakes at stop
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by t clements, Sep 20, 2014.
  1. t clements
    t clements New Member
    lebanon me
    my 2009 shake for a few seconds when i stop at red light, what causes this
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Is it shaking after u've stopped or during?
  3. t clements
    lebanon me
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    The ICE might be misfiring before it shuts off when you come to a stop.
  5. t clements
    lebanon me
    what is the "ice"
  6. jadziasman
    1,355
    487
    District 6
    internal combustion engine
  7. writes123
    writes123 Junior Member
    92
    23
    Riverside, CA
  8. t clements
    lebanon me
    i had the spark plugs replaced about 300 miles ago. i have 118000 miles on it. what else would i check.
  9. vskid3
    vskid3 Active Member
    773
    228
    Did it do this before changing the spark plugs? What spark plugs were installed?
    If its while you're still moving and pushing the brake, it could be warped brakes. The regen would make it more difficult to detect at higher speeds compared to most cars.
    If its after you stop, it could just be the ICE shutting down, especially if its still warming up.
  10. bisco
    49,725
    how is your oil level?
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    If it's only during the stop, I would look @ ur brake rotors.
  12. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
    Totally normal. Use the search function.
  13. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    This could easily be normal behavior associated with the engine turning off, but it could also be something wrong. Without being able to compare it to another Prius, you're going to have to give us more information. Is there a sound associated with the shaking (and if so what, can you tell where it seems to come from)? You said it is only during braking, not after you're fully stopped?
    If you suspect the rotors, it might help to get to ~35 mph (NOT exceeding 42, stay lower) and put the car into Neutral and come to a stop. Do this preferably on an empty street, as the braking characteristics will be different than you are used to. It will only be using the physical brakes, and no regen. I'm not sure (someone else will have to chime in) but this might also keep the ICE from turning off/on while you're in Neutral. Don't leave the car in neutral after this test, and basically never use neutral because the battery cannot be charged in neutral, and the car's electrical motors can be damaged by going too fast (I think it's 42mph+ causes MG1 to exceed its rev limit).
