Car shudders
Discussion in 'Gen 2 Prius Main Forum' started by carleric, May 18, 2007.
  1. carleric
    carleric New Member
    Houston, TX
    Every morning, after I start my car and drive to work, when I stop at the first light my Prius "shudders" and gives a small shake as it powers down. When the light changes, it starts up fine, and this shudder only happens once a day.
    Is this normal? It doesn't seem like anything to be worried about, but I'm a new Prius owner and (more than a little) paranoid about treating it right.
  2. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(carleric @ May 18 2007, 09:46 AM) [snapback]444784[/snapback]</div>
    If you are referring to normal engine turning off, the shudder is much more noticeable with a cold car... This what I interpret as a once a day to mean.
  3. Earthling
    Earthling New Member
    441
    Somewhere, NY
    My Prius does the same thing.
    Engine shut-down is most noticeable the first time, when the engine is just barely warm enough for a shut-down. Later, when fully warmed up, it is much smoother and less noticeable. I don't worry about it.
    Harry
  4. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Normal, no big deal. It's probably burning fumes from the EVAP cannister or something.
  5. hill
    8,248
    Welcome to P.C.
    The search tool is a wonderful thing. You type in shudder, and lo & behold ... BOOM oodles & oodles of the same topic! Over and over :p
    Yep, it's normal. Funkie, but normal. Just pretend your Prius is feeling a little chilly & it just shivered.
  6. ystasino
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(hill @ May 18 2007, 10:27 AM) [snapback]444820[/snapback]</div>
    Actually the search engine does work much better than most forum search engines I've used!
  7. carleric
    carleric New Member
    Houston, TX
    Oh, man. The search tool. I just noticed it. Yeah, that would have been a better way of going about things.
    Sorry. :)
  8. Neicy
    Neicy Member
    834
    Wakefield, MA.
    <div class='quotetop'>QUOTE(ystasino @ May 18 2007, 10:30 AM) [snapback]444821[/snapback]</div>
    I just asked the question last week too!!! I think it's something we all notice at first and get scared something's wrong with the car. Now if I had a nickel for every time it was asked.....
  9. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    Maybe your baby saw an H2 and was shuddering in revulsion.
  10. jamarimutt
    jamarimutt New Member
    985
    Get used to it. At 62,000 miles my car shudders just the same.
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I believe that is the transition between Stage2 and Stage3a?
    The stages
