car shuts down spontaneously when idling
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stuart Cracraft, Jan 11, 2014.
  1. Stuart Cracraft
    Stuart Cracraft Junior Member
    San Juan Capistrano, California
    I have a 2012 Prius. It has twice shut down spontaneously when idling
    while in traffic. I have explained this to Capistrano Toyota in San Juan Capistrano
    and the Service Advisor said he had never heard of it but will discuss it with
    Service Director Andy Fu. My question to people on Priuschat is: why is
    this happening? The car has been properly serviced. It never happened with
    my 2006 Prius.
    Stuart Cracraft
    49,437
    the thing you have to know about cap toyota is, thier first response to every problem is 'huh, never heard of that before'. yeah, right. and make sure they pay for your towing costs!:mad:
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Did the dealer even bother to check for error codes? Wrong forum, BTW.
    "Shuts down" doesn't really describe much. What exactly happens? Does the whole system reboot or what?
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The OP has at least 3 threads started in different forums. Reported to mods for consolidation.
    Said in another thread that no forward power, so has to shut down and restart.
  5. bisco
    49,437
    i wonder if disconnecting the neg bat cable for a min would fix this.
  6. Stuart Cracraft
    Dealer did not even ask or bother to check for error codes. Didn't ask me to come in to check for them. Nothing.
  7. El Dobro
    El Dobro A Member
    6,978
    3,213
    Ask for a manager.
  8. bisco
    49,437
    the only good thing about nothing is it's free.(y)
    ou812 likes this.
  9. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Sounds very normal to me! Is this not what it's meant to do. Hard to save fuel with the ICE running :)H
  10. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Stuart - obviously this is a problem you need fixed pronto. A lot of the folks here are very knowledgeable and incredibly helpful. I'd advise you give us as much detail as possible - anything and everything.
    Someone mentioned removing the negative battery cable for a few minutes. This essentially resets a bunch of settings. It is not all that likely to solve the problem, but it can not hurt. Just be prepared to reset things like the radio presets, etc.
    Good luck.
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Is the OP putting the car in Neutral causing a low HV battery situation, and thus the car shuts down?
  12. bisco
    49,437
    i think that's exactly what's happening. a lot of people put thier car in neutral when stopped.
    GrumpyCabbie likes this.
  13. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    The only time I put my prius in neutral is to back out of my garage or some other parking space. After coasting backwards I put it in drive.
