Car Shuts Off please help me figure this out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Galina Hana, Feb 16, 2020.
  1. Galina Hana
    Galina Hana New Member
    Seattle
    I have a Prius 2013. It's been randomly shutting off every couple of weeks. This is what my car does: I will arrive at the destination, and without any issues lock the car usingk key fob.
    1. When it's time to go home, I will use the key fob to open the car. The car responds without issues.
    2. Then I attempt to start the car but it is fully dead. It won't start, there are no overhead lights, it's like the car battery is dead. (The battery 12v is new, just changed.)
    3. A wait a few minutes, I get out of the car, use the key fob to lock / unlock the car, the car responds and beeps.
    4. I start the car but it will only shift to neutral or park, it will not shift to drive or reverse.
    5. I will shut off the car and turn it on again and then it starts working like normal.
    Every time this happens the car clock will be missing a few minutes (5-15mins) and there are no abnormal lights or codes to let me know that there is an issue.
    I can't figure out why this pattern works to get the car working again.
    Thank you for your help!!!
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Your car is still showing symptoms of a bad 12v battery.
    Galina Hana and RMB like this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Not sure how recent or where you purchased that 12v,
    but I would recommend going back to see what can be done.
    It may have been sitting around for a while until you purchased...and may have lost its charge.
    Galina Hana likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    or it may just have a bad connection
    Galina Hana and dig4dirt like this.
  5. Galina Hana
    Seattle
    Thank you for the info. Going to go look at the battery.
    dig4dirt likes this.
