Car slightly thrusting forward
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, May 26, 2018.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    hello, i have an '06, and i just noticed something about it, when the car is in parking mode and the gas engine starts, the car slightly thrusts forward, (if the handbrake isnt engaged) all i want to know, is, whether this is some kind of a problem or not. :) (probably of the transmission, i think)
    thanks in advance!
  2. audiodave
    audiodave Active Member
    798
    269
    US
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Normal.
    Its really not moving forward at all its just the engine torque makes it feel like that. The car must be new to you. I bought my 07 new and the first time it did that it was holy cow what was that.
  4. fuzzy1
    10,335
    My previous '10 and current '12 always did this.
    The Park pawl has some significant slop (or backlash, in mechanical terms) to it, allowing a slight movement. But since that pawl is solidly engaged and quite strong, the car can't move much.
  5. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Very normal. Did Uber in my gen 2 at the airport and you almost fall asleep at idle in a state of relaxation waiting for the app to ring. Then out of nowhere car thrusts forward. One time there was a car that looked only inches away and I jolted up and it really caught me by surprise.
    Another odd thing is I used to get shocked (literally as in zapped) almost every time I shut the door but I think that was in the winter months. Surprisingly there are tons of threads on it:
  6. fuzzy1
    10,335
    This is mostly a clothing-vs-seat-fabric issue, creating static as one pulls away from the seat and exits the vehicle. My 1983 Ford and 1986 Honda where significantly worse for this than either of my Prii.
    MilkyWay and edthefox5 like this.
  7. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Fuzzy is correct.
    Your going to get shocked on everything if you don't use dryer sheets. Bounce is the best it says right on the box it's anti-electronic .
    Fabric today is cheap china nylon fiber the absolute best stuff in the world to static charge. All you need to do is throw it in the dryer.
    No Bounce and in the winter oh boy that's gonna hurt.
    Few times we have run out of Bounce at home i could get a half inch long blue shock to the racks at work. I make sure we never run out. Never ever get a shock.
    MilkyWay likes this.
  8. audiodave
    798
    269
    US
  9. fuzzy1
    10,335
    Just a terminology correction: Static is electric, not electronic.
    For us old-timers in the field, this is a source of increasing aggravation. But with electronic devices taking over nearly everything that used to be just electric, it may be a losing battle to keep the younger generations straight on the proper terms.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    You mean like calling this "#" a hash tag? :D
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Agreed it actually says Collement Electrostatique on the box of Bounce so I said f it and wrote electronic. I'm an old timer too 40 years Electronic Engineering & bench tech been in Broadcast for the last 20 years FCC First Class still working full time. So yes I know the difference.
  12. GeorgeMW
    57
    Georgia
    alrighty, guys, thanks for the info!
