Car towing with trailer
Discussion in 'Prius v Technical Discussion' started by Profanas, Apr 1, 2020.
  1. Profanas
    Profanas Junior Member
    35
    Lithuania
    2013 Prius+ MPV
    Hi guys
    I have Prius Plus+ EU version
    And i wanna tow another car with trailer
    Car about 1200kg +trailer 300kg
    I know Prius afraid of towing, maybe because when towing with rope, Prius gearbox always have some kicks.. but with trailer gearbox dont have those kick, and all are stable.
    Im right? or not...
    where are problem?
    I have another car, e38 bmw, but problem bmw dont have car hook.. :/
  2. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    It will probably tow it, the problem will be stopping it. I think that is double the towing weight specified for your V.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  4. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I would never tow another car with a class 1 hitch. It isn't strong enough.
    Then again, I would never tow anything bigger than a bicycle with a Prius. I like my transmission too much to abuse it.
  5. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Prius should not be used to tow another car, the hitch, chassis and brakes aren't strong enough, and you might overheat the transmission or inverter with the excess load.
    From the research I've done the maximum is less than 900kg
  6. Profanas
    35
    Lithuania
    2013 Prius+ MPV
    OK thanks, i will tow with my old tank e38
