Car turns on with no Fob in it
Discussion in 'Gen 2 Prius Main Forum' started by Venluckey, Apr 28, 2018.
  1. Venluckey
    Venluckey New Member
    Yesterday i drove my car from work to a local place to eat, it fired up came to life and drove fine. When i went to leave the place, i put my FOB in and got no response from the dash. I got a Jump and the main battery came on.
    When i got back to work, i turned it off and at break (2 hrs later) i tried to turn it on again, and it gave weak dash lights and went off. Then it refused to come back on, so i closed the door and started to walk away and heard the radio come on. The dash was all lit up and no FOB was in the ignition. I put he FOB back in and turned it off again. I got a jump again and got it home, where i turned it off and back on gain with no problem.
    Today I tried to start it it looked like a weak battery, so i turned it off and took the FOB out and sure enough about 30 seconds later the dash came to life. I put the FOB back in and the car cranked. I turned it off and took the FOB out.
    What all of sudden causes this? Since i bought this used, I am guessing it has the original 12+ battery, it says Panasonic on that battery. When I do Diagnostics from touch screen, says 14.1V when running, 12.3V when in ACC mode.
    Any ideas, i have a trickle charger and can see if that battery can be revived.
    Car Info:
    Prius Manufactured 11/03
    No Navigation
    No Mods
    VIN= JTDKB20U140027523
    Mileage=154,274
    Sat 2 years in a garage before being sold to me in, had 57,284 miles when sold to me. Had 1 inverter pump replaced and dash recall performed.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    #2 kenoarto, Apr 29, 2018
  3. Venluckey
    Battery shows 12.4v steady, had a friend do a scan on the car. Seems the main battery is failing.
  4. Mendel Leisk
    38,790
    You started the car with the fob. The weak 12 volt battery made it appear to not be on, but it apparently was. Walking away from a Prius that's on, with the fob, the car will continue to be on.
    jerrymildred likes this.
  5. Venluckey
    I have never been able to remove the fob if ihe car was on, I don't have the smart fob, just basic.
  6. Mendel Leisk
    38,790
    Oh hang on, second gen, does the fob have to be in a socket? My mistake. :oops:
  7. bisco
    49,587
    only on non sks models.
  8. kenoarto
    398
    Chicago, IL
    Was that after a full night's rest and tested as detailed in the link?
