Car Wash and putting car in Neutral
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Dec 11, 2017.
Tags:
  1. Sid786
    Sid786 Active Member
    262
    146
    Cherry Hill, NJ
    Yesterday I went to an automatic car wash and they asked me to put the car in Neutral and let the car wash drive the car through. But as it started moving, all the radars starts beeping for collision detection (as this was not a touch-less car-wash). When I stopped the ignition to stop all the beeping, then the automatic car wash didn't work, as if the car was in Parking.
    Eventually I had to take the car out of the car-wash and had to put it to the touchless car wash.
    Can someone please let me know that how can I take my Prius Prime Advanced through the regular car-wash.
  2. Sid786
    262
    146
    Cherry Hill, NJ
    I found this on a different forum for Prius GEN 2, is this still valid for Prius Prime Advanced:
    Power the car down, then, without pressing the brake pedal, press the power button twice. You will see all the usual dashboard indicators and be able to work the various acessories. Now, depress the brake pedal and shift into "N." The vehicle will now be in neutral, but will not be in the "Ready" state, so it can't magically shift itself into gear and tear off on a wicked spree of maniacal car wash mayhem.
  3. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Same thing happened to me last week during the first time through the car wash. I just ignored the warnings and the car made it through just fine. There is probably (don’t have the manual with me) a method to disable the sensors, but the only one I was the least concerned about was the front collision sensor applying the brakes because I was only 8 feet or so behind the car ahead.
  4. Mendel Leisk
    Mendel Leisk Witness Leader
    39,633
    Avoid the pull-along style carwashes, use the kind where the car drives in and stop, and the apparatus moves. That resolves the issue you mentioned, and avoids the further issue, that the hybrid battery can be run down to dangerously low levels. Maybe not an issue with the Plug-Ins though.
    The traditional pull-along style car washes were designed anticipating a car could be off and in Neutral, which is not the case with the Prius unfortunately.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    huh......I go to the car wash all the time, (the kind that pushes the car along while the brushes wash the car) and have never had nary a peep out of my car (2012 PIP, 2015 PIP and now my 2017 Prime) when I arrive at the car wash I wait for the car wash attendant to direct me in pointing left or right if I'm not directly in the track of the car wash traction device. once he gives me the thumbs up I apply the brake momentarily and shift into neutral, easy peasy :D
    Mark57 likes this.
  6. CraigM
    208
    208
    Portland, Oregon
    I guess the “worry” is that forward collision sensor would see the brushes, and chamois strips, and apply the brakes. I made it through the one time I went through the tunnel, but still wonder if the brakes will lock next time?
    Craig
  7. Mendel Leisk
    39,633
    Can you turn those sensors off?
    Off-topic, but if your sole method of cleaning the car is via these car washes, you'll be missing the corners, wheel wells, and any scrapes/dings that might require touch-up.
  8. Mark57
    2,945
    2,738
    OK
    Yes
    Tha_Ape and Mendel Leisk like this.
  9. CraigM
    208
    208
    Portland, Oregon
    Looks like page 478 of the manual discusses turning the brake assist off. I’ll try to test this next time I’m out.
  10. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    You would -think- the car would know it's not actually moving and wouldn't apply the brakes. Maybe I'm expecting too much?
  11. Prodigyplace
    12,025
    11,479
    Central Virginia
    You have been fortunate then. People have run down the 12 volt battery because it is not being charged when the car is in Neutral.
  12. CraigM
    208
    208
    Portland, Oregon
    Guess I’m not following this. How can the 12V battery be run down during the 5 minutes it takes for the car to go through a drive-thru car wash?
    priuscatprimeguy likes this.
  13. Prodigyplace
    12,025
    11,479
    Central Virginia
    Lights, radio, heating fan, MID, ECUs. Some ECUs must be 12 volt since they can get confused when the battery is too low.
  14. priuscatprimeguy
    2,730
    2,640
    heating is using heat pump from traction battery even in neutral:D
  15. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    I have an "All you can wash" monthly plan at our local automatic car wash. Never had a problem, however, I do have to ignore the beeps as the brushes pass around the car. Never have the brakes come on in over 20 washes. Only thing I have to remember is to turn off the rain sensing wipers to avoid damage from the brushes.
    PT Guy and priuscatprimeguy like this.
  16. priuscatprimeguy
    2,730
    2,640
    lol, yup, I forget every time :p, when the car washer guy sprays the windshield with his sprayer I then say, "oops!"
  17. David Beale
    5,963
    1,985
    Edmonton Alberta
    Actually the 12V battery is still being charged in "N", but the traction battery isn't. Best to turn off A/C before entering. It's the only large load on the traction battery. Though with a PIP or Prime you'd think the traction battery is big enough to take it. ;)
  18. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    In most "normal" situations it won't.
    But if you enter with a weak, worn out battery OR you keep high draw accessories running.......then you might have a problem.
    I think this is so rare that even mentioning it is crying wolf when there is none.
    Edit: And as someone else mentioned, I think the problem really was depleting the HV battery if you entered with it low.
  19. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Just don't worry about it. Put the car into N and let the beepers beep. I do it a couple of times every week. No problem.
    chenderson2 likes this.
  20. For a few years, I had been going to a touchless car wash where I could park my car and let the machine go around.
    Well, this year's "upgraded" car wash included... BRUSHES!! :eek: :mad: :mad: :cautious:
    So I decided to use a different one with a track. I turned off the pre-collision system, along with the clearance sonar, and rain-sensing windshield wipers (and a few other things that I don't think mattered), and put it in to neutral. No warnings, no buzzers, no glitches, no problems.
    #20 Deleted member 111882, Mar 6, 2018
    Mark57, benagi, padroo and 1 other person like this.
