Car Wash Mode
Discussion in 'Gen 5 Prius Main Forum' started by KH111, May 20, 2024.
  1. KH111
    KH111 Junior Member
    37
    17
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I recommend practicing putting the transmission in neutral before your first trip through an automated car wash. I embarrassed myself when I struggled with it to the amusement of the workers. Note: it's a simple sideways pull on the shift knob, nothing forwards or backwards. The shift diagram on the console is helpful if you remember to look at it. Additional note: It's my wife's car so I'm not totally familiar, but still:(
    Also, what settings should be turned off to avoid unnecessary collision warnings going off as the various brushes attack the car?
    KH
  2. CruisnGrrl
    CruisnGrrl Active Member
    149
    125
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I would recommend against using an automatic car wash, you may not have clearance under the car for the tow.
    From page 486 of the manual.
    ■Automatic car washes
    ●Before washing the vehicle:
    • Fold the mirrors
    • Turn off the power back door
  3. RandyPete
    RandyPete Member
    172
    53
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    When the car in in N mode, the 12v battery does not get any charge from the traction battery thru the DC-DC charger in the Inverter. If you are running the AC at full tilt, the 12v battery voltage will go down. May not be a problem, and yet again it could be. Turning off the AC and fan could avert this use of the 12v battery when it is not recieving power from the Hybrid System. Turn off the day-run headlights could also help.
  4. PTS
    PTS Member
    62
    26
    Austin, Texas
    2013 Prius v wagon
    The hybrid battery won’t charge in neutral which is the problem.
  5. bisco
    49,488
    if it's a prime, charge it before going
  6. KMO
    KMO Senior Member
    1,541
    425
    Finland
    2023 Prius Prime
    So that would then apply to most cars? The G5 Prius isn't unusually low - indeed it's higher than a lot of previous Priuses. Never seen one of these "move the car" car washes - don't think they exist here in Europe? But I struggle to believe they've invented something unsuitable for most cars. (But then maybe that's why they don't exist here...)
    That's all totally wrong. N decouples the engine and motors and hybrid battery from the drivetrain. The 12V system and A/C remain connected to the hybrid battery.
    So no real problem in that area for a plug-in Prius, unless you're at "---" on the battery gauge, at which point you have the same issue as a non-plug in, you might manage to deplete the hybrid battery.
  7. AndersOne
    AndersOne Active Member
    283
    165
    Europe
    If you mean with "move the car" washes these up to 50m long streets where you get pulled through while your car is washed and "waxed" in many ways including light shows and giant blowers - we have a lot of these in Germany at leat in urban areas. How else would lazy people like me wash their cars? I never had a car though where not eventually something fell off while using one - small price for convenience.
    EDIT: Example Mr. Wash - Germany's fanciest car washing facility - Team-BHP
    I never folded mirrors in my cars - they are usually folded by outside force. But the power back door sounds scary. What could happen? The button gets accidentally pressed?
    #7 AndersOne, May 21, 2024
  8. KMO
    KMO Senior Member
    1,541
    425
    Finland
    2023 Prius Prime
    I've only ever used and seen the less-fancy "the car stands still while the rig with the brushes and nozzles and blowers moves backwards and forwards" washes.
    (I imagine there's a technical/trade name for these types :cool: )
    AndersOne likes this.
  9. KH111
    KH111 Junior Member
    37
    17
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I have used a "Quick N Clean" car wash near us for years and it has never broken anything on our vehicles (Honda Ridgeline, Scion Xb, Honda CRV and now the Prius) or scratched our paint. There was plenty of clearance on the guiderails and the Prius rolled through nicely once I figured out the "N" position on the tranny. I can't imagine battery life is an issue for the 3 minutes it takes to run through the carwash. I stayed in the vehicle but I read in the manual on pg 260 there is another procedure to follow if you want to get out of the car and not have it automatically switch to "P". I will have to experiment with that this morning.
    Still not sure what to turn off to keep the warnings from activating. Just parking sensors?
    KH
  10. Mendel Leisk
    38,726
    This style negates the need for the car to be on, in Neutral, etcetera.
    still, if practical/possible: an occasional handwash is good, to get in the wheel wells, underbody, all the corners/edges/recesses, and to check and deal with minor damage.
    #10 Mendel Leisk, May 21, 2024
  11. Trollbait
    11,560
    It's related to the current door recall. Sealant for an electronic module fails in the field, allowing water intrusion that can cause it to open the door. I believe the first case happened in a car wash.
  12. Hammersmith
    Hammersmith Senior Member
    1,337
    1,390
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I believe the first case happened while the car was moving.
    I'm the source of the misinformed car wash story. I read the recall documents late one night and got some of the details confused when I posted the next morning. (I think it was KMO that caught my mistake.)
    Toyota duplicated the issue during testing by using something like a pressure washer wand spraying at the rear door seals. I misremembered that as the original case being caused during a car wash.
    SM-S901U ?
    Trollbait likes this.
  13. ColoradoBoo
    ColoradoBoo Senior Member
    963
    631
    Monument, Colorado USA
    You're not alone and I've owned a Prius since 2017! We had a new car wash built with those stupid conveyer belts and I, also, cause them to shut it down until I could get it into neutral.
    But it's not a brushless wash and would flap my mirrors back and forth even though they were already pulled in so I stopped going. (And their Yelp reviews had numerous folks reporting of mirror damage.)
  14. CruisnGrrl
    149
    125
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    With North America's obsession with SUVs you see a lot more ground clearance on most other cars. The one time that I tried the automatic pull your car car wash one of my mudflaps caught on the track, fortunately it didn't break but that was the first and last time I used an automatic car wash, I wasn't impressed with the job it did either. Now I take it to the bay where wash it yourself but I probably wouldn't be opposed to the "touchless" ones where you drive in and it moves around you if there was one near by.
  15. Trollbait
    11,560
    I only use car washes for the under carriage spray. I know some manual bays have a nozzle for that, but haven't seen such for the auto wash that moves around the car.
    Regardless, until the car has the recall fix, you want to be sure the steps have been taken to prevent the fault opening the rear doors before going through a car wash.
  16. RandyPete
    RandyPete Member
    172
    53
    2024 Prius Prime
    XSE
    I don't think the fault OPENS then rear door. I think it unlatches the door. Still has to be physicaly opened bu someone something.
    Have yoiu ever triedd to push the door open while driving down the highway at 35-55 MPH. It takes much effort. now driving with a rear door unlatched and getting in an crash/accident might causee the door to open.
  17. Jeff606
    Jeff606 Junior Member
    26
    SF Bay area
    It's called a "Drive through automatic car wash"
