car wasnt working and mechanic deleted something electronically and it worked again. explanation????
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jjkim87, Oct 18, 2021.
  1. jjkim87
    jjkim87 New Member
    north hollywood ca
    the question = title
    can anyone explain what in the world just happened???
    before this there were all warning lights
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Generally speaking, when there are warning lights being displayed on the dash, there will be OBD2 codes stored in the computers (ECUs)
    Did the mechanic(?) record or write done the OBD2 codes (DTCs) before deleting them? (always a good idea)
    FYI : you're being moderated until you've posted 5 times.
  3. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    Sometimes clearing a code will allow the car to go back to operating normally. It is a temporary fix and may not work long, until the code is rethrown. Meaning you have to actually repair the problem that's occuring.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    THIS.
    If that is ALL he did, the original problem is still there.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You probably have a bad hybrid battery and it is throwing a ground fault code.
    That will put the car into limp mode meaning no contribution of the hybrid battery then on engine only and car then has no power.
