car wax?
Discussion in 'Gen 2 Prius Main Forum' started by pete bogumill, Jul 8, 2006.
  1. pete bogumill
    pete bogumill New Member
    57
    i know there are a lot of car wax's out there and they all say that theirs is the best! but what is the most durable and most long lasting that any one has tried and really works? does it have to cost a lot to be good or is that a bunch of bull? also does it leave a white powder all over and go on hard and come off hard etc. some input please. thank you . pete :unsure:
  2. meezercat
    meezercat New Member
    115
    I'll be interested to hear what people have to say too. I've never waxed a car, but if it would be a good idea to wax the Prius, I'm all for it.
  3. DavidTO
    DavidTO New Member
    102
    I'm no expert, but on my other forum, someone who DOES know, suggested the following, all ordered from carcareonline.com.
  4. pete bogumill
    57
    <div class='quotetop'>QUOTE(DavidTO @ Jul 8 2006, 04:51 PM) [snapback]283083[/snapback]</div>
    hi david... got your info on the wax. thank you. :rolleyes: pete
  5. DavidTO
    DavidTO New Member
    102
    <div class='quotetop'>QUOTE(pete bogumill @ Jul 8 2006, 02:57 PM) [snapback]283085[/snapback]</div>
    Here's the original thread. It's more informative than I could be.
  6. Tideland Prius
    16,151
    www.toyotanation.com
    go to Detailing and Car Care
    They have some good stuff there (especially the Sticky which has a detailed list of how to properly clean the exterior (polish & wax included) and interior.
    Otherwise, most of the best "waxes" are actually polymer based and aren't natural waxes.
  7. Godiva
    Godiva AmeriKan Citizen
    10,339
    That's a good start, but I'd add two things.
    1. Use a grit guard in the bucket. In fact, use two buckets, one for shampoo and one for clean rinse water. I have a grit guard for both.
    2. Never use a leaf blower to dry your car. You could be blowing grit back on your car.
    I like the detailing advice on Meguiarsonline.com. You can use their method with any product, but I like Meguiars.
    5 step paint care plan
    Here's a whole set of links.
  8. mr.whit
    mr.whit Member
    117
    Michigan
    I enjoy cleaning and waxing my cars, I have found what I think is the best and easiest wax to use and the fastest. Check this link out and you can order from this on-line store http://www.zainostore.com/, I liked how my Prius looked when I was done, also it has held up well. :)
  9. pete bogumill
    57
    <div class='quotetop'>QUOTE(Godiva @ Jul 9 2006, 03:37 AM) [snapback]283268[/snapback]</div>
    hi godiva. got your info and also saved the set of links that you sent me. thank you very much. pete ;)
  10. MadHungarian
    MadHungarian Member
    139
    Atlanta and Miami Beach
    Consumer Reports (July '06) found that liquid "wax" usually beats paste. Unfortunately, Zaino was not included in the test.
    The top rated liquids were Black Magic Wet Shine liquid, Turtle Carnauba, and Eagle One Nanowax. The best paste, Nu Finish NFP-80, overall score was lower than the top four liquids (tied with the fifth highest liquid).
    Overall scores were based on gloss, durability, ease of use, cleaning, scratching/hazing, and compatibility with plastic. And I have greater trust in controlled comparisons (even CR's) than anecdotal reports--excepting those for weight loss products, of course!
  11. brandon
    brandon Member
    771
    Manhattan, KS
    Not to start another Zaino fan thread, but I detailed my Zaino experience here:
    http://priuschat.com/index.php?s=&showtopi...ndpost&p=259377
    Several months later, I'm still very pleased with the results. A friend used the Meguiar's products on his Crossfire and said he was pleased with the results, as well.
  12. fatale
    fatale New Member
    28
    Toronto, Canada.
    If you have a black car - Zanio Zanio Zanio.
    I use Eagle One Quick Wax (spray wax) which is now called "Wax as you dry". It has a supringly good shine that seems fairly durable. I wax it on once a week or so... amazing.. I use it on all of my classic Austin Minis with great results.
  13. Tideland Prius
    16,151
    <div class='quotetop'>QUOTE(MadHungarian @ Jul 9 2006, 08:55 AM) [snapback]283346[/snapback]</div>
    Sorry, I'll disagree on the liquid part. The turtle wax I used to use was weak. It'd last a max of 2 weeks.. maybe 4 if we're careful about parking the shade and not driving often.
    The paste wax I'm currently using was last applied on my car at the end of April and the water still beads. Unfortunately, the same wax applied to my dad's car who's parked outside 24/7 (home & office), and last waxed in mid February definitely needs a wax job. So at least the paste lasts at least 2 months, not more than 4 if parked outside 24/7.
  14. Godiva
    10,339
    If I were going the paste wax route, I'd buy a dual action polisher and sets of pads and learn how to use it properly. I tried paste wax by hand once...never again.
    BTW I have a GS-100 DA polisher and use it with Meguiars new NXT products. Love it.
    And I love their ScratchX.
  15. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    ZAINO
    check out my pics.
  16. JEBster
    JEBster New Member
    I second (or fourth) the Zaino recommendation. It takes quite a bit of work to get started (6 hours to claybar and apply), but worth the effort. Great stuff.
  17. barbaram
    911
    70
    Trenton, NJ
    Pete-
    since the car is new you can probably forego the claybar unless you really have a lot of sticky bug grime. Dawn does remove alot of it. I skipped it the first application but will probably do it next time-
  18. brandon
    brandon Member
    771
    Manhattan, KS
    The claybar is intended to remove a great many things that can be found on even the newest of cars. Zaino's claybar product info page gives some good examples of what the claybar is intended to remove. Small snippit:
    So you are probably asking if I ran a claybar over my entire car. No, for no other reason than I was lazy and knew I still had a lot of work ahead of me. I just hit the "key" areas like the front, around the wheels and around the portions closest to the road.
  19. NuShrike
    NuShrike Active Member
    1,378
    I'm wondering if I should break out the G100 porter and Zaino the Vaio magnesium lid. It gets oily. Maybe claybar first.
  20. Nda3rdCar
    Nda3rdCar Junior Member
    92
    <div class='quotetop'>QUOTE(pete bogumill @ Jul 8 2006, 02:00 PM) [snapback]283069[/snapback]</div>
    :D I'm one of those people who enjoy hand waxing a car... I've tried a lot of products, but the best I've used is "One Grand, Blitz Wax". Easy to apply and wipe off. Easier the second time. It's made in Ventura California and has instructions like.... "use 100% cotton diaper, or t-shirt material". We have a black Prius and our other car is silver. The Blitz wax really makes the black a glossy-pitch-black. The metallic silver is really brought out as well. Strange looking stuff when you first use it. Carnauba Paste Wax.... not a polish that can use abrasives.
    You pay a bit more, but lots of uses and a very good product. $20 or so per can.
    One Grand Products, Inc. is the company name and they have a web site. They make other detailing products.
