Car won't go to ready mode after cell replacement.
Discussion in 'Gen 2 Prius Technical Discussion' started by mmmadog, Jul 18, 2023.
  1. mmmadog
    mmmadog Junior Member
    16
    Evergreen state
    2004 with 280k. Had a bad cell number 13 so pulled the battery and replaced it having done this before about 40k before so not new to this and have mechanic experience. Put the battery back in and thought I better check it before bolting it back in. Car come on beeps say problem and won't go to ready mode and has the red triangle. Pulled it again checked every cell for voltage and all seemed good. I have double and triple checked everything but stumped on what it could be. Any help is much appreciated.
  2. Brian1954
    Brian1954 Active Member
    797
    299
    South Central PA, USA
    You have trouble codes that need read since you have the red triangle. Retrieve the trouble codes and come back and tell us what they are.
  3. spdracrm3
    spdracrm3 Member
    43
    37
    estacada or
    You sure you installed battery safety plug fully and pushed down handle till fully seated?
    SM-G960U ?
    donbright and mmmadog like this.
  4. mmmadog
    16
    Evergreen state
    Yep that was it. Should have read a little before posting. I'm 62 and short term memory isn't what it used to be. Prius chat is by far the best and informative car forum I have ever been on. And I have been on a few.
    donbright, spdracrm3 and bisco like this.
  5. mmmadog
    16
    Evergreen state
    Well got car running but Dr prius app now showing cell 14 is bad and cell 1 not much better. Drove it for awhile to charge it real good and Red triangle comes back on and car barely makes it home. Got code p3020. Car is just to old to put a bunch of money in it.
  6. bisco
    49,387
    a lot of us are facing the same situation in a difficult car market
