Car Won't Turn Back On/Turns on By itself
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ProfessorChaos, Dec 12, 2025 at 10:44 PM.
  1. ProfessorChaos
    ProfessorChaos New Member
    Yesterday
    Louisiana
    Four Touring
    Hello,
    I have been following some previous threads and have some similarities but cannot find my exact issue.
    Previously, when I would turn the car off, sometimes it would turn back on right after shutdown. Recently, after shutdown, it will not turn back on at all and require a jumpstart. When I shut it down, not even the anti theft warning light stays on and the car is completely dead. I have troubleshot the following: 12V Battery tests good, no visible corrosion or loose connections (Connector was previously loose, but tightened and seemed to fix for the interim). Inspected C2 fuse, no visible defect. After putting it back in, then the car worked fine for a couple days. Replaced the fuse anyway just as a precaution and the car turned on fine at O'reillys but when I got back home, it would not turn back on. Code scanner picked up a few codes, most relevant being C1241 for brakes? - Low or high power supply - recommends inspecting/clean battery terminals and perform battery test. B1421/B1442 (Air Conditioning solar sensor/air inlet damper) P3102 - Transmission Control ECU, C2122/C2123 - Tire pressure monitor transmitter ID not received.
    Used scanner for Hybrid/EV battery Test(1-14) - All cells measured 15.4 except cell 4 measured 15.3 but graph shows green regardless.
    Interesting anomalies: When I took a multimeter to the 12v, it sparked slightly and the car turned on (accessory mode). Similarly I disconnected the 12V negative ground for 1 hour and when I screwed it back in, it sparked and the car turned on again. For clarity, the spark is similar to if you were to jump it. Also when the car was completely dead and I went to manually lock the doors in the back by moving the lock button, it turned on as well. At one point when trying to jump it previously with a jumper pack, the car was saying something about parking on a level surface and engaging the parking brake. I believe this was due to the jumper pack being low on battery as I had done it a few times before and when my friend came with his, he jumped the car from the 12v itself, not the terminals near the fuse box and it worked fine. This was random and again I think the jumper pack was just not putting out enough power.
    My friend recommended swapping out the main fuse/fusible link and I will be heading to the store in the morning to see if that helps. I had seen a video where the gentleman does this but talks about how the check engine light would turn on when trying to turn on the car. Again, I have no lights at all but once the car turns on it is completely fine.
    I had seen a different thread talking about the wire harness running from the 12v being bad, but before I ripped the whole car apart I was open to other suggestions as this seems slightly extreme, but I am running out of ideas.
    Also, the driver's side headlight flickers. This may be completely unrelated and I bought a replacement headlight today, but when I went out to the car, I noticed it was completely dead again and didn't bother replacing the bulb as I was focused on the electrical issue of the car not starting.
    Power button does not seem to stuck and the key fob battery was changed within the last 3 months. Weather is mild, but not cold enough that it should be an issue.
    My guess is whatever should be triggering to keep minimal power after shutdown must be failing, but I am not sure. Will be swapping the main fuse tomorrow, but open to suggestions as well.
    Thank you for your time.
    - A guy who just wants to drive.
  2. Brian1954
    Brian1954 Senior Member
    2,203
    866
    South Central PA, USA
    How old is the 12v battery?
    Everything you wrote indicates a problem with the 12v system in the car. It is a battery issue or a wiring/connection issue. The first thing I would do after the car does not start, is to use your meter to measure the voltage at the battery terminals and also at the jump point in the front of the car under the hood. How do the voltages compare to each other? Do you measure 12+ volts at the battery terminals?
    51,932
    get the 12 volt load tested free at most auto parts stores.
    why would jump starting work? let's use our brains
  4. pasadena_commut
    pasadena_commut Senior Member
    2,633
    785
    Southern California
    Only starts when jumped? Presumably at the jump point. Battery tests OK? That suggests that the 12V battery is not actually wired into the car. The car will run without a 12V battery, but of course it cannot start that way. Jump at the jump point, car sees enough 12V to start and can keep running. Shut down is strange? Pretty much what one would expect since the 12V will crash when the car turns off and their is no battery in the circuit to keep the voltage up. Consequently, the car's shutdown logic will be scrambled.
    Triple check that the negative ground at the battery is OK. I would suggest taking the cable completely off at both sides, clean the ground point and loop until they are shiny metal, then bolt the cable back on at the ground point. Clean the inside of the post connector. Clean the post (using one of those cup like brushes where the bristles are on the inside.
    It seems unlikely, but with it off the positive battery post and unplugged from the car, measure the resistance between the point where it clamps onto the positive post and the socket where the big cable plugs in. It should be very low.
    Measure the resistance across positive cable (unplugged, at the battery post to the jump point under the hood). The meter leads won't reach, but clamp a jump cable on the jump point, pull the other end around near the battery, and measure resistance. It should be very low.
