Carbon fiber front and back Toyota emblem mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ucsmfu, Jul 13, 2012.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    Was able to get an exact fit carbon fiber vinyl to replace the heat blue insert. Gonna take the opportunity to plasti dip the emblem too :p
    the front and back emblems have 3 clips holding it, once you remove it it's pretty easy :)
  2. xliderider
    xliderider Senior Member
    8,026
    3,204
    Honolulu, HI
    "Exact fit" carbon fiber vinyl can be found on eBay, but the vinyl is cut into 6 pieces that are meant to be applied to the emblem without taking them off.
    If you are taking the emblems off, why buy an "exact fit" vinyl when you could cut a sheet to fit? :confused:
  3. Russ D
    Russ D Junior Member
    22
    So Cal
    There is an easy answer to that... the "exact fit" vinyl pieces are cheaper than most of the rolls you can buy from China, you don't have to wait for the shipment from China, and it's already cut out so you don't have to spend your own time cutting everything out. Some people want to do it themselves, other people like the convenience. Why go out to a restaurant if you can go to the grocery store and make a meal for yourself?
  4. TruSound
    TruSound Member
    246
    32
    The 818
    Looks great, can you please provide the link to the seller...thanks.
  5. ucsmfu
    1,498
    420
    canada
  6. TruSound
    TruSound Member
    246
    32
    The 818
    Look forward to seeing it...thanks. The EBay seller lives 15 minutes from me
  7. ucsmfu
    1,498
    420
    canada
  8. Russ D
    22
    So Cal
    Looks awesome! :cool:
  9. MMMpg
    MMMpg Junior Member
    CA
    any tips on removing the emblems?
  10. Russ D
    22
    So Cal
    The front is easy... pop the hood and there is an access hole. Put your hand in there and undo 2 of the 3 clips holding it in. Pops right out.
    Back is easy also, just more complicated than the front. Put a card (such as a credit card) under the chrome Toyota emblem on the left or right side and push toward the center of the car. It will release the side clip and enable to emblem to be free from the rear hatch.
  11. ockevin
    ockevin Active Member
    493
    148
    Orange County
    I got the same one, arrived fast and I installed both in 10 minutes total.
  12. ockevin
    493
    148
    Orange County
  13. billydon
    billydon TSS Limited Edition
    Gun Barrel City Tx
    Kevin, did you plasti dip the chrome logo in gunmetal? And put the carbon fiber insert behind it?
    The match to the winter grey looks perfect, was debating on buying the plasti dip in smoke or gunmetal, and the clear to give it a little gloss. Yours looks like a perefect match
  14. born_again
    born_again Member
    103
    47
    Rancho Palos Verdes, CA
  15. daevumshlebee
    daevumshlebee New Member
    what did you dip the emblem in to? and could you describe the process?
    I love the way this looks. I have the nautical blue metallic, and the bright blue of the emblem clashes....if i don't do the plastic dip, the carbon fiber insert alone will improve this look tremendously
  16. ucsmfu
    1,498
    420
    canada
    just plasti dip, remove the emblem, stick the carbon fiber insert on the heat blue plastic piece, you can find the precut carbon fiber inserts on Ebay. for the chrome Toyota emblem, you spray that with plasti dip, 3-4 layers, wait about 20 min in between each coat. Than at the end you can choose to apply matte or glossifier coatings depending on your liking.
    cheers :)
  17. Fore
    Fore Don't look back!
    494
    107
    [​IMG][/quote]
    Hey, where did you get the right and left lower guards below the fog lights?
  18. ucsmfu
    1,498
    420
    canada
    Hey, where did you get the right and left lower guards below the fog lights?[/quote]
    that's part of the Prius Plus body kit
  19. ockevin
    493
    148
    Orange County
    search on youtube for plasti dip and you will see the whole process.
  20. itengineer
    itengineer Member
    85
    25
    Minneapolis
    Just did this carbon fiber mod. Looks good. Thanks for the eBay link.
    I passed on the plasti-dip for now.
