Careful When Washing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rest, Sep 3, 2008.
  1. Rest
    Rest Active Member
    1,210
    53
    CA
    So I washed my Prius today and by chance found a couple small rubber bumpers in my driveway. Not sure what they were I decided to check my car doors as they seemed familiar. I found the driver and passenger door lower bumpers were missing.
    Be very careful when washing your car as they pop off very easily when you wipe the car down.
  2. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    Good to know, thanks!
  3. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Thanks! Good tip. Probably also a good idea to check if you take it to a hand car wash.
  4. SCfromSC
    SCfromSC I take my gas in a sippy cup
    56
    South Carolina
    Take the car back to the dealership to get them put back on. You should still have some bumper-to-bumper warranty left.
  5. Rest
    Rest Active Member
    1,210
    53
    CA
    They just pop back on, there was no need to go to the "stealership" for this.
  6. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Thanks for the heads up and pics.
    You might bring it up next time you are at the dealership. They might have some replacements since yours are prone to fall out. That way you will have some backups if nothing else. They might even be redesigned so they stay put...although I've been disappointed with Toyota in this regards on my Tundra. (Blower knob plastic cracked around shaft as did the rear window hinge--ordered aftermarket aluminum replacments for the latter, pain in the a$$ to install such a simple part.) Other Japanese cars I've owned tend to have fixes for common failures like that, rather than putting back in the same part so that it fails again within a few years.
  7. Rest
    Rest Active Member
    1,210
    53
    CA
    I won't be visiting a stealership anytime soon for something this minor, major engine issue yes but not for this. I prefer to stay away from stealership parts and service departments. I am sure though they could provide me with replacements, but not for free. Mine are not prone to fall out (on their own), they fell out because as I was wiping the inside of my doors and I must have knocked them out. Usually I am more attentive to what I am doing, must be getting old. I doubt Toyota will change the design of these door bumpers as it isn't a safety issue and I am sure they don't ever fall out on their own.
    I only posted this as a heads up, especially for those that have others wash or maintain their Prius. If you didn't know they were there to begin with, then you wouldn't know they were missing, note to self.
  8. bjjb99
    bjjb99 Junior Member
    22
    Northern VA
    I think SCfromSC's "bumper to bumper" warranty comment was intended as humor since the issue concerned rubber door bumpers falling off. I found it funny, at least. :D
    BJJB
  9. hill
    8,172
    Same thing with the rubber pad on the parking brake. It snaps off & on way too easy. A little bit of epoxy on BOTH is the way to keep 'em from being an issue.
    Cheers
  10. dwreed3rd
    742
    Marietta, Ga
    Gerat idea! I'd use a clear silicone cement though, something less permanent than epoxy in case thay ever need to be removed for whatever reason.
  11. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Never really paid attention to the rubber stoppers...I think mine are still there, but will check when I get home.
