Cargo cover dimensions
Discussion in 'Prius c Main Forum' started by Dan8906, Jan 19, 2020.
  1. Dan8906
    Dan8906 New Member
    Concord, Ca
    I just bought a 2013 Prius c and it doesn’t have a cargo cover. I found the part number to be 64330-52410-B3. But I can’t see spending $200 + on a new one. So I’m just going to make one out of thin plywood. Can someone provide some pictures and dimensions of theirs please! Thank you
  2. davidc83
    davidc83 Member
    116
    51
    Scottsburg, Indiana
    2015 Prius c
    If your C isnt a level 2 or higher, there are no hooks/connectors for a cargo cover
    SM-S367VL ?
  3. topshot
    topshot Member
    152
    58
    Midwest
    2015 Prius c
    It would be simplest to pick one up from a junk yard.
    If you really want to make one, the dimensions are easy enough to determine from the space it fills. There is also one on Ebay for $130 that includes some pictures for you.
    dig4dirt and Dan8906 like this.
  4. Leadfoot J. McCoalroller
    8,187
    7,692
    Pennsylvania
    2018 Prius c
    I've seen at least one thread about a homemade cover, search around a bit more.
    Dan8906 likes this.
  5. Dan8906
    Dan8906 New Member
    Concord, Ca
    Yes I made one already. Easy enough. Just used some 1/4 plywood. Going to need to add something soft so it doesn’t rattle over bumps.
  6. topshot
    topshot Member
    152
    58
    Midwest
    2015 Prius c
    If you looked at those Ebay pics, you can see 2 rubber bumpers on the end against the hatch and a rubber (?) piece on the bottom of each side where it lays on the ridge.
  7. topshot
    topshot Member
    152
    58
    Midwest
    2015 Prius c
    I looked at mine and the piece on each side seems to be a felt-like material. It's definitely not rubber.
  8. Cougartwo
    Cougartwo New Member
    If you still need a cargo cover, I will sell mine for $45. It's in Seattle - you pay shipping. Sadly, I totaled my beloved Prius C.
  9. Prieth
    Prieth Junior Member
    17
    NM, USA
    I might do this depending on shipping cost...Could you give me a total with shipping to 61107 zip?
