Cargo Cover Usage, Rattle
Discussion in 'Gen 3 Prius Main Forum' started by erikl, Aug 25, 2010.
  1. erikl
    erikl New Member
    36
    SF Bay Area
    Hi all, quick question on the cargo cover. When I received the car, the cover was extended with the small end piece flap pointing slightly upwards. This covered the lower window of the hatchback a little, but the plus side is that there is no rattling.
    I've noticed that the flap settles in either a horizontal, or upwards position. I'm not sure if this is by design.
    I've adjusted the end flap so that it is horizontal, but the cover rattles now. How do you have your cover set?
  2. SamelCamel
    SamelCamel New Member
    60
    Kansas
    If I remember correctly, the edge of the cover settles in a slightly downward angle....
    -Sam
  3. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    I have mine set mostly horizontal with a slight downward angle. No rattling for me, and I retract and pull out the cover very regularly.
  4. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    Hmm, I notice some kind of rattling from the back too. Time to investigate if it's the cargo cover, thanks.
    On another note I've been thinking of how to block the sun's heat by covering the big rear window. Now can we use the cargo cover to do that by mounting it up high near the ceiling? another thing to investigate!
  5. dmvp
    dmvp Member
    364
    Lot's of people that have heard rattling from the back come to find that the back headrests are the culprit. Make sure they are locked into place.
