cargo deck cover shade advisory
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bob Allen, Aug 10, 2004.
  1. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    This week's helpful hint: A little advisory for you folks: Yesterday, I found a tiny flathead screw on the carpet in my trunk. At first, I thought it belonged to something I had been carrying, but in any case, I knew to keep it in case some "hole" showed up. Later, I went to close the "hidey-shade" over the trunk and discovered that the little tongue pieces on the rear end of the shade that engage the slots in the side panels, would not engage. The reason is that those little tongue pieces are screwed to the shade and one of the screws was missing.
    After re-screwing the missing screw, I checked and found all four were loose. I'd suggest you check those screws and make sure they are tight. If I had had a trunk full of camping gear or another assortment of items, I might not have noticed the missing screw or found it if I did. It would be a silly but necessary trip to a dealer to get a replacement screw.
    Next week: How to arrange flowers in your cup holders.
  2. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Oh man, I can't wait.
    Every time I make right turns my flowers shift and drive me crazy!!
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    That's a pretty widely reported issue/problem...thanks for the reminder. I don't use my cover at all, but haven't checked the screws.
    Seems the main problem is that they're a little too short and tend to loosen up. Folks might think about trying to similar but slightly longer screws to replace or add some loc-tite to make sure they don't vibrate loose again.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    just a dab of hot melt glue and screw it back in never to come loose again.
  5. removeum
    removeum Member
    407
    El Paso, TX
    Cargo Cover
    Thank you for the information. I also found the small screw about a week ago. Just checked and I was missing two of those. Guess it is back to the dealer ship.
    Ben :mrgreen:
  6. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
  7. toyoprius
    toyoprius New Member
    109
    Boston
    All four of my screws loosened and fell out also.
  8. chgomatt
    chgomatt New Member
    Chicago
    People have been telling me for years that I had a screw loose. I just went out and checked and I actually had 3 screws loose! :)
  9. montolchik
    montolchik New Member
    33
    Mentor, Ohio
    I lost both on one side. The dealership replaced them when I went in for my last oil change.
  10. daniel
    14,487
    1,518
    Spokane, WA
    I do not know... if you glue the flowers into the cupholders you'll have to clean out the hardened glue after the flowers fade. There's got to be a better solution.
  11. Frank Hudon
    4,147
    Daniel, I'm starting to see a pattern here with you taking things out of context.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    LOL Frank
    I've had one come out of each side as well. Started about 6 months ago. I regularly tighten them down, but do need to add some glue or loctite. Wonder if the "newer" Prius experience this, or just the early release 2004's?
  13. Frank Hudon
    4,147
    I'm not sure if it's just us early adopters or not but I've looked at this design and I'm of the opinion that Toyota should have put a metal insert in the plastic end portion when they injection molded it. That would have allowed the screw to actually bite into something other than plastic. The hot melt on the screw and tightened back in has stopped them working out for now.
  14. pjdemmitt
    pjdemmitt Junior Member
    25
    Columbia, MD
    Loose Screws
    I noticed earlier today that one of the screws was starting to come out and made a mental note to tighten it when I got home. It wasn't until just before I decided to to to bed to do it. However, it was too late! The screws on one side had come completely out and the plastic guide was off. I looked in vain for the missing screws, but couldn't find them. I knew that they just didn't disappear.
    So removed the entire metal housing and shook it. I could hear the screws rattling around in there. It took a bit of shaking and pulling on the cover, but I was able to recover the missing screws from inside the metal housing.
    If your screws are misssing and you can't find them in the trunk, check the metal housing. Chances are, that's where they are.
    I used to use Locktite, but the little tubes would dry out before I was able to use it all. I like the hot melt glue idea. The next time I have work to do on the car, I will remove them and do that.
  15. daniel
    14,487
    1,518
    Spokane, WA
    :lol: :lol: :lol: :lol: :lol: :lol:
  16. removeum
    removeum Member
    407
    El Paso, TX
    Loose Screw or I have one missing
    I check and one of the screws is missing. I went to the dealership and attempted to buy a replacement screw. Wouldn't you know, there is no part number for it and the whole cover is listed as one part.
    The dealership said no problem, ordered me a new cover and said it was covered under the warranty.
  17. jamarimutt
    jamarimutt New Member
    985
    Toyota should replace the cheap shade with a useful hard cover that pivots up when one opens the rear door. My 1998 Daewoo Lanos had such a cover, as did my 2002 VW Golf. In both cases the cover was made of a material light but rigid enough that you could use it as a shelf. The Prius shade is a joke by comparison.
  18. HTMLSpinnr
    5,339
    917
    251
    While a hard cover is more durable, it's not as "storable" as the soft cover. Speaking as someone who's have 2 other hatchbacks in the past with hard covers (1993 Ford Probe and a 2002 Hyundai Elantra GT Wagon) - I prefer the storable version - though the risk of tearing the cover is present.
    Our cover can be placed under the "floor" of the hatch in a specially designed area to keep it out of the way. A hard cover wouldn't be so easy to relocate if you happened to get something large at Home Depot some weekend.
  19. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    What about using a frog for the flowers. BTW for the uninitiated a frog is a usually round device with a heavy stainless base and a "bed of nails" on top to poke flower stems into. Should be heavy enough to hold your flowers with out glue.
