Cargo liner with lip?
Discussion in 'Prime Accessories and Modifications' started by MTN, Nov 5, 2019.
  1. MTN
    MTN Active Member
    306
    276
    SB, CA
    Looking at purchasing a better cargo liner than the OEM Toyota "all-weather" one that came with the car. (message if you're interested in buying)
    I can't find a good picture of the Weathertech one
    Their website is zero help:
    2020 Toyota Prius Prime | Cargo Mat and Trunk Liner for Cars SUVs and Minivans | WeatherTech
    -- no actual product photos.
    Amazon and eBay have this:
    Which makes it look like the lip is reduced or missing completely from the rear section. Is that right?
    Does anyone have one and could you please provide some better photos?
    We also do not have a Husky liner option for the cargo area and the Canvasback has no lip. We want to protect the battery area from wet items (SCUBA gear, etc).
    Thanks in advance!
    #1 MTN, Nov 5, 2019
  2. MTN
    MTN Active Member
    306
    276
    SB, CA
    bump - does no one own a Weathertech cargo liner in a Prime? Seems strange - any help appreciated!
    (Tried emailing WT - we'll see how that goes...)
    edit - they responded with a photo (and looks like they edited/clarified their webpage with same photo) - it definitely drops down at the rear. Likely due to how the Prime's battery is elevated above the cargo floor / opening. Makes sense I guess. I was hoping for a better "bathtub" style design to contain water if needed, from surfing/diving gear. Not sure the WT is much better than the OEM for this.
    #2 MTN, Nov 7, 2019
  3. Tideland Prius
    16,615
    What about this OEM one?
    Toyota Prius Prime Luggage tray
  4. MTN
    MTN Active Member
    306
    276
    SB, CA
    Interesting. It still has some cut-out areas of lower "lip" and the $75 s/h definitely says "no".
    I'm just mainly thinking of how much we need to worry about damp items and the battery. I'm sure in reality, we won't have an issue using the standard OEM all weather one.
  5. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    MTN likes this.
  6. Tideland Prius
    16,615
    The battery is towards the rear seat. The trunk lid is where the storage bin is located. Also, the battery is on stilts so any liquid that does drip in won’t touch the battery.
    MTN likes this.
  7. DavidA
    2,348
    1,823
    Chicago western burbs
    I purchased the WT rear cargo liner this past summer. Fits well, and I'm not worried about the lower height of the lip at the back. One additional advantage with WT is no plastic smell whatsoever.
    MTN likes this.
  8. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    I debated the custom vs universal cargo liners from Weathertech. Was worried that the raised lip on the custom liner would get in the way when loading things with the rear seats folded. Was also worried that the rigid liner would make it hard to access the charger cable compartment underneath.
    I decided to go with the universal one. It took a bit of patience and careful cutting to install. Material is good quality but price wasn't cheap either! Still less expensive than the custom liner. So far I don't regret the decision.
    IMG_20200607_201910.jpg IMG_20200607_201852.jpg IMG_20200607_201840.jpg IMG_20200607_201846.jpg IMG_20200607_201844.jpg
    Tideland Prius and MTN like this.
