Cargo Net
Discussion in 'Gen 2 Prius Main Forum' started by afed, Mar 20, 2007.
  1. afed
    afed New Member
    My dealer just mailed me a cargo net for my 2007 Prius which was missing from the car when delivered. The cargo area has 4 O-rings in the 4 corners by the rear hatch. However, the net has 2 clips along one edge, but stretchable rope loops along the opposite edge. It's not clear what they would attach to. Shouldn't it have 4 clips? Does anyone else with a 2007 have the cargo net to check how it is supposed to be attached? Did the dealer send me the wrong net?
  2. Acelin
    Acelin Junior Member
    51
    Everett, Washington
    Sounds to me like the dealer sent you the wrong cargo net. The 2007 net should be identical to the 2006 net which has clips at all four corners. The cargo net kit should include two D-ring mountings and a set of templates. You have to drill a couple of holes (using the templates to show you where) and press the D-ring mounts in.
    Is it possible that your cargo net includes a couple "T" mounts? That would explain why you have loops at the top of the net instead of clips. There should also be templates and drilling instructions otherwise I think you have the wrong net.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I agree, the net you have sounds like the one for my wife's Highlander Hybrid which had some 'cleats' built into the car that those stretchable loops hook to.
    The Prius net should come with 2 plastic D-rings that you have to drill holes for then install...there are instructions and a template to make it easy.
  4. onree
    onree Junior Member
    49
    Central NJ
    Just to be clear -- there is also a horizontal cargo net that simply a rectangular piece of netting that has four clips, one on each corner, that clip onto the four d-rings that are already in the cargo area (two in front, two in back).
  5. Jimtak
    Jimtak New Member
    24
    Napa, Sonoma
    The cargo net I got for my 2007 Prius came with 4 clips - two for the in-place steel D rings on the floor, and two for the two neat D rings that you need to install in the plastic panel which also contains the slot for the retractable cover. Sounds like you were sent the wrong net, one designed for the Sienna or Highlander which have T knobs to attach the net with the loops.
  6. YoDaddyAlex
    YoDaddyAlex Member
    271
    where can I get the net that doesnt have to be drilled into something?
  7. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(YodaddyAlex @ Mar 20 2007, 12:27 PM) [snapback]409016[/snapback]</div>
    do you mean the horizontal net or the upright net like the OP is describing?
    The horizontal are a little tough to find but there should be something on Ebay...it's not a Toyota OEM item for Prius.
    Here's One for $22
  8. afed
    afed New Member
    Thanks everyone! Sounds like I was sent the wrong net. The O-rings came preinstalled on the car, all 4 of them so luckily I don't have to drill or install anything. I think this car was supposed to come with the cargo net, that's why the rings are there. When I saw the loops on two corners of the net, it looked more like the net I have in my Honda CRV which has "T" brackets instead of rings for mounting.
    Will get the dealer to replace it. Thanks again.
  9. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Howdy afed
    You have several correct answers; however, if it's still not clear to you, here are some photos of the vertical cargo net ("envelope" type} and of the rings to which the net would attach. You can also purchase an aftermarket "flat" net which could be used to secure cargo on the cargo floor. I believe the one I have shown is the one delivered with a Prius. Hope this clarifies if for you:
    [attachmentid=6969]
    [attachmentid=6970]
  10. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(afed @ Mar 20 2007, 01:34 PM) [snapback]409061[/snapback]</div>
    Be sure to look at Charles' photos. The pre-installed 4 metal D-rings are actually mostly for the tire tie down straps you should have gotten with your car. But the rear-most two are the bottom anchors for the net you'll get from the dealer (you'll get the vertical envelope, not the horizontal one). Thus, you will still need to install those 2 black D-rings you seen in the photos.
  11. Truffles
    Truffles Junior Member
    56
    Antioch, CA
    And installing the plastic rings is quite easy.
    Just use the templates, the right drill bit and go slow.
  12. mario24601
    mario24601 New Member
    Los Angeles
    Which net version do you recommend?
