Cargo Net
Discussion in 'Gen 2 Prius Audio and Electronics' started by SolarSiStar, Jul 16, 2007.
  1. SolarSiStar
    SolarSiStar New Member
    Hi All,
    I recently purchased a cargo net from Prius chat but now it appears i need to drill 2 holes into an area where to attach the upper hook-ups for it?? Where should i get this done right since i dont want to make mistakes in doing it myself? :unsure:
    thank you!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Suck it up and do it your self! Seriously, I strongly encourage folks to do this on their own. It's very simple, you tape the included template in place, get a drill with the proper sized bit, slowly drill a hole in the plastic. There's nothing back there to damage, the bit will go through the plastic like butter.
    You'll have a nice sense of accomplishment of doing a small mod on your own.
    If you just can't bring yourself to do it ask someone comfortable with tools to do it...it's just too easy to pay money to anyone to have it done.
  3. SolarSiStar
    <div class='quotetop'>QUOTE(efusco @ Jul 16 2007, 04:36 PM) [snapback]479823[/snapback]</div>
    I've always been someone to do things on my own but i'm still surprised there wasn't an already built-in spot for this specific net to be hooked up without drilling a hole into my new vehicle B)
    thank you!
  4. Armature
    Armature New Member
    55
    Scottsdale AZ
    <div class='quotetop'>QUOTE(SolarSiStar @ Jul 16 2007, 02:50 PM) [snapback]479829[/snapback]</div>
    I installed my cargo net when my 2005 was less than a week old. Courage! It's a piece of cake!
    To quote Nike, "just do it!"
  5. SolarSiStar
    Ok, i'll ask my handyman neighbor next door for his drill and a 8mm drill bit and i'll get to drilling 2 holes into my baby:) just as simple as that, right?
    thanks for the encouragement![attachmentid=9800]
  6. BellaHMB
    BellaHMB New Member
    44
    So a silly question but..... how does the template tape onto the floor? Does the little curve fit with the
    curve of the car?
    Victoria
  7. christob
    christob Member
    183
    Arlington, VA
    Victoria---the original photo shows the net spread out on the floor---but the 2 hole will be drilled up on the left and right sides of the plastic wall material, so that when the net is in place, it sit "vertically" across the cargo space, and opens like an envelope or pouch. Two anchors already in the floor of the Prius hold the bottom corners of the net, and the installed/drilled hooks, above, hold the upper corners.
  8. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Wow, pretty car. :D
  9. SolarSiStar
    <div class='quotetop'>QUOTE(ChristoB @ Jul 18 2007, 09:30 PM) [snapback]481360[/snapback]</div>
    Its done, i had a mechanic at Toyota do it while i was there having them also set my bluetooth for me:)
    [attachmentid=9927]
  10. BellaHMB
    BellaHMB New Member
    44
    <div class='quotetop'>QUOTE(SolarSiStar @ Jul 19 2007, 12:01 PM) [snapback]481646[/snapback]</div>
    Your photo is really helpful!! Thanks!
    Victoria
  11. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(SolarSiStar @ Jul 19 2007, 10:01 AM) [snapback]481646[/snapback]</div>
    That explains why you posted this topic in the Audio and Electronics forum.
  12. Hemi4Prius
    Hemi4Prius Geek Girl
    44
    Morro Bay, CA
    I'm confused... I want to get a cargo net, but the only ones I found are spread across the bottom of the floor, like a spiderweb.. but your picture and description shows the envelope style.
    I want the envelope style net like yours - are they one in the same? :confused:
    I saw some on eBay but they are all show the spiderweb picture.
    TIA!
  13. Linden
    Linden New Member
    47
  14. Another
    Another Senior Member
    1,802
    510
    Naples, Florida
