Carista questions
Discussion in 'Prime Accessories and Modifications' started by mistermojorizin, Jun 19, 2019.
  1. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    I've tried searching but couldn't figure this out. Figured this belongs under modifications.
    1. Where is the option to disable the pedestrian warning sound? (the sound made under 15mph on the outside of the car)?
    2. Under doors and locks, there's this option: "open trunk via smart access button" and it's set to "long press." Does that just mean holding the driver's door handle for a longer time opens the trunk together with the other doors?
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I don't believe this option exists. The sound is required by regulation, I believe.
    PrimeDan and mistermojorizin like this.
  3. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    Thought of another question: under "other" there is a couple of "pre-collision system" (PCS) options. One says
    *default distance for PCS alarm when the ignition is turned on with the PCS switch on* This currently says "remember last distance". The other one says
    *PCS sensitivity: remember last state* This currently says "disabled"
    The rest of the PCS options say "FAR"
    What do those 2 options do?
  4. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    You're right. To answer my own question, you can make it louder in carista, but not turn it off. It's under instruments/displays/dings and it's called Vehicle proximity notification system beep volume. Using that as a search term helped me find this thread on the forum, with this particularly useful post: Disable the grindy speakery thingy?
    PrimeDan likes this.
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Tip for free - don't make your turn signal click volume too low. If you normally have some good tunes going, you won't hear it and it is easy to leave the blinkers on. In bright light the arrows aren't obvious.
  6. Diemaster
    Diemaster Active Member
    295
    260
    so. cal
    First thing I did to the Prime. took the warning speaker out and packed it full with about 5 packing peanuts. keeps the speaker form moving and making sound.
    mistermojorizin likes this.
  7. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    Haha, thanks. I actually made the turn signals louder and extended the blink duration to 7. Love me my turn signals (from Cali where many don't use them), hate when I can't tell if they're activated without looking at the instruments. I'll see if it's too loud tho.
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Tach?
  9. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    Ha, I edited it right after posting.
  10. Diemaster
    295
    260
    so. cal
  11. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I wish it wasn't a subscription service... I wouldn't even care if they just locked it to one vehicle. I just want to change some things and see how they go (I'll need more than a week for that).
    I already have the bluetooth obd2 reader. So buying the carista one for 1 month free service isn't worth it
    AzusaPrius likes this.
