Carlinkit 3.0 Mini CarPlay Wireless Adapter
Discussion in 'Prime Accessories and Modifications' started by eow, Jan 28, 2022.
  1. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I decided to give this adapter a try.
    https://www.carlinkit.store/collections/mini-carplay-box
    One of the easiest installs I have experienced. I had to allow connecting via Bluetooth on my iPhone, then I accepted a connection on the PP. Two selections and it was up and running.
    Rather than using the supplied cable, I installed it with a USB A to USB C adapter:
    USB 3.0 SuperSpeed Type A Male to Type C Male Adapter Converter Connector | eBay
    This way it is tucked away and not occupying the cup holder.
    iPhone ?
    #1 eow, Jan 28, 2022
  2. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Here are a few other images:
    iPhone ?
  3. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    First impressions and observations:
    Ran around the city today and using Siri and navigating went well as did the sending and receiving of iMessages that are dictated and announced. Using Siri for phone calls went well with the exception of a few calls dropping off. Hopefully it was not the adapter. Time will tell.
    iPhone ?
  4. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Loaded an update that hopefully addresses the phone call drop off issue.
    The S/W version was 11 months old as received.
    iPhone ?
  5. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    I've been using that exact mini unit since August. First on my 2021 C-HR then on my 2022 Prime. Haven't had any issues. Once in a blue moon, the Prime's HU gives an "Apple CarPlay error". I unplug the mini and plug it back in (or I used to). I now have it plugged in with one of these cables:
    https://store.obsbot.com/products/usb-a-to-usb-c-data-power-cable-with-on-off-switch
    If I get the error, I toggle the switch off then back on. I have the cable running into the center armrest and have the mini sitting on the felt-lined tray.
  6. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    The rocker switch cable looks like a good option if a restart/ reset is required.
    iPhone ?
    Darien Day likes this.
  7. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Seems like the S/W update took care of the phone call drop issue. Was on a 13 minute call today and had no issues.
    iPhone ?
  8. Npurdy1112
    Npurdy1112 New Member
    IN
    2022 Prius Prime
    Still worth the purchase a week after your last update? Considering purchasing this after having my phone plugged in and charging for a long road trip, just felt it was unnecessary when I only needed carplay features not charging.
  9. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Yes it was worth the purchase. I find that I am using it a lot for dictating iMessages and having Siri navigate with voice commands.
    And it takes no effort to connect now like it was with the cable.
    iPhone ?
  10. Npurdy1112
    IN
    2022 Prius Prime
    Good to hear. did you purchase from the link in your original post? The payment processor name made me a little leery. "PingPongPay"
  11. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Yes , the link I posted for the Carlinkit store.
    But if you are in the USA, it may be cheaper on Amazon for you.
    iPhone ?
  12. Npurdy1112
    IN
    2022 Prius Prime
    thank you! Try to avoid amazon when possible, but its a decent price savings.
  13. Acadianer
    Acadianer Member
    118
    81
    Technology
    Hmmm, I'm liking this. Probably be like $200 to bring it in Canada lol
  14. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    It cost me $71 USD to bring to Canada per my original post. I found it to be worth the money.
    iPhone ?
    Acadianer likes this.
  15. gene
    gene Member
    98
    NH
  16. Acadianer
    Acadianer Member
    118
    81
    Technology
    Anyone have reviews of the 3.0 vs 4.0 vs 5.0? My iPhones lightning port is a tad finicky, so it keeps disconnecting. They within 30 bucks of each other at the moment.
    3.0 $75 bucks
    4.0 $101 buck
    5.0 $106 bucks
