  1. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    I just saw a short review of CarMD (CarMD.com) in PC World today. It is a hand-held device that plugs into a car's On-Board Diagnostic Port II. It gives indications of (1996 or later) car problems that are spelled out more clearly, with diagnostic codes and possible fixes, when you re-attach the device to your home computer's USB port using their software.
    Where is this port on the Prius? Anybody have any experience/ideas if this is a worthwhile gadget for our favorite car? It connects on-line, with car registration necessary, and is good for up to three cars, allowing a maximum of three reports a month per car. It gives unlimited reports of smog-test-pass predicability. It costs $90, not sure if for year or forever.
    BTW, does the Prius need to be smog-checked in California?
  2. catmother
    catmother IEEE Life Member
    23
    So California
    The Prius does not ever require smog testing in California. In fact, existing smog test equipment is not capable of testing the Prius.
    I have an OBDC tester purchased from Kragen on sale about a year ago. About $50. This is a basic tester that will read all the mandated general codes (but not manufacturer specific codes) and will indicate all faults in that category. I can also reset fault codes and reset the check light. Have not ever needed to do this on my Prius.
    The OBDC connecter is under the dash, forward of where the drivers knee is. The tester works fine on the Prius and on any OBDC compliant car. Every compliant car is required to have a placard under the hood whick lists OBDC compliance. My Prius has such a placard.
    My reader is made by Innova, www.codereader.com The Prius uses a "scanbus" and the Innova reader is scanbus capable. You can get this tester at any autoparts house or probably cheaper from an internet dealer. There is no computer interface on this tester.
    No experience with CarMD. Some owners like the Scanview tester, more expensive but much more versatile.
    Peter
    K6OPY
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(PAK @ Aug 9 2006, 04:56 PM) [snapback]300493[/snapback]</div>
    The exemption is in place only until January 1, 2010.
    Here is the link:
    State of California Department of Consumer Affairs Bureau of Automotive Repair
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    have you actually pluged it in and see if it can connect to the car Most Innova readers can't. Unless it say's CAN capable it won't find the car. I've got one in the basement that can't find the CAN buss in the 2k4.
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(Alnilam @ Aug 9 2006, 06:20 PM) [snapback]300470[/snapback]</div>
    It looks like all you have is the one time upfront cost - no cost to use the report generating feature or the website (i just went in and registered to see if it would ask me for money - can't find anything that does)
  6. catmother
    23
    So California
    <div class='quotetop'>QUOTE(Frank Hudon @ Aug 9 2006, 11:50 PM) [snapback]300645[/snapback]</div>
    As I said in my post "The Prius uses a "scanbus" and the Innova reader is scanbus capable. "
    My reader is the model 3100, I have tested it on the 06 Prius and it works properly
    Peter
  7. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    DMV site clearly states no Smog check for Hybrid vehicle
  8. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Drift Motion @ Aug 11 2006, 12:36 AM) [snapback]301366[/snapback]</div>
    This is what the the State of California Department of Consumer Affairs Bureau of Automotive Repair clearly states:
  9. Richard Harris
    Richard Harris New Member
    Moncks Corner, SC 29461
    How do you use the CarMD on a Prius 2012? The CarMD manual says the car has to be ON, but not cranked, how do I get to that On with having the motor cranked?
  10. bisco
    49,375
    welcome! try pressing power once, or twice, without pressing the brake.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    How much is the CarMd?
    I would be surprised if it can pull Hybrid Codes.
  12. Richard Harris
    Thanks for the information!
