Carpet is cut (has holes) under the driver seat
Discussion in 'Prius v Main Forum' started by slawek, Sep 1, 2014.
  1. slawek
    slawek Junior Member
    Did anybody noticed on the Prius v, under the driver's seat the carpet having cuts (holes)?
    Looks like it has been cut there for some reason. Maybe to access something?
    I noticed that a long time ago when I bought the car new. I recently out of curiosity checked another prius v at the dealer in the showroom and it had the the same cuts, although a little less then mine.
    Did anybody noticed the cuts too? And maybe knows why they would be there?
    #1 slawek, Sep 1, 2014
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,162
    6,316
    Texas Hill Country
    which model?
  3. slawek
    This is a Canadian "Luxury" model (we have 4: Base, Luxury, Touring, Touring+Tech)
  4. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    For routing seat heater or power seat wiring?
  5. rjparker
    10,162
    6,316
    Texas Hill Country
    I would agree wiring unless it's there to accommodate the rear seat vent (easily seen from the rear).
  6. slawek
    There are no cables going through the holes.
    The carpet under passenger's seat does not have cuts like.
    Here is the link to some pictures of the carpet under driver's seat (shows cut carpet):
    Carpet under driver's seat in Prius v | PriusChat
    Does anybody has cuts in the carpet like that?
    #6 slawek, Sep 1, 2014
  7. rjparker
    10,162
    6,316
    Texas Hill Country
    My 2012 v3 has the same cuts. The front one (at minimum) covers a captive nut in the floor. I would assume some Toyota option would have a mounting bracket under the driver's seat that bolts on through those openings. Maybe the advanced navigation has a box under there. Alternatively the mounting opportunity could be useful for installing an aftermarket amp to feed the back speakers.
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Isn't that where the satellite receiver would go? Mine has a large plastic box under there.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    could it be the air intake for the battery cooling on the Li-Ion battery versions ?
  10. slawek
    Not in this model as it is 5 seater with nickel-metal hydride (NiMH) battery.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Maybe they use the same carpet set though ?
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    In the GenII Prius, the cutouts are there for the navigation system's wiring harness and attachment bracket. Similar holes on the passenger side can be found for the JBL amplifier.
    I would assume for the GenIII it is the same reason. In those with nav, the box goes there. In those with the high end speaker system, the amp goes under the other seat. The holes in the carpet are just the way it comes on all models, even the base rental Prii package 1's.
  13. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    My 2012 V has this also. Not sure why. The flaps cover it, but when looking under the carpet flaps, there is nothing of interest there. Just the metal floor of the car.
