Caster adjustment...not possible?
Discussion in 'Gen 3 Prius Technical Discussion' started by SagradaFamilia, May 30, 2014.
  1. SagradaFamilia
    SagradaFamilia Junior Member
    U.S.A.
    2018 Prius
    Good Day, I've just replaced the tires on my 2010 Prius III with Michelin Defeners and had the suspension aligned by the dealer where it was purchased. All but one parameter were adjusted into specification. Right-Front Caster, however, was measured at 5.0 degrees both before and after final adjustment. This is just out of the specification of 5.1 degrees. The services representative checked with both the alignment mechanic and a senior mechanic and reported that the caster is not adjustable on this vehicle so I am left with three questions:
    1) Is this true....is caster not adjustable on this model?
    2) I was told that it would not affect tire wear, and my road test showed good alignment with nice tracking and breaking. Recent gas mileage has also been consistently above 50mpg. So, is there a risk with this being out of specification?
    3) The car has not been in any kind of collision and I don't recall any impacts that I thought would damage the suspension. Have you any experience that might explain this oos condition.
    Thanks for your thoughts.
    Marty
  2. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Caster affects turn in response. I wouldn't worry about it unless you're concerned about lap times.
  3. hlunde
    hlunde Member
    419
    75
    Absolute caster is not as important as having equal caster right and left.
  4. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    I agree with the above responses, it's not likely to cause any kind of abnormal tire wear. Generally a tenth of a degree out of spec isn't enough to do much even if it was toe or camber.
  5. Tideland Prius
    16,445
    Interesting. I had my dealer do a wheel alignment while it was in for service. One of the notes said that the right front caster was lower than the left but within specs.
  6. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Wheel alignment is as much an art as a science. We used to set up cars with the drag link in front of the control arms closer to the positive end of the spec and if it was behind, to the negative end. The best alignment guy we had was as good with a carpenters square and measuring tape as the machine. He built a limited sportsman class local half mile track race car every year and never once brought it in to be alighned. He did it in his garage at home. Guy was a real master at it. I drove it around his neighborhood once. Let go of the wheel and it would go hard left. If it bothers you take it to a frame shop. Just don't watch when they wrap the chains airing it and start bending. This is how you used to have to alighn the old Ford twin I beam suspension pickups. If you were smart you did this they day you bought it. Tire wear was horrible right off the lot.
  7. SagradaFamilia
    U.S.A.
    2018 Prius
    Wow, with all due respect, I'm surprised that a definitive answer to the question "Is caster adjustable on a Prius III, 2010? is not forthcoming. Toyota overtly assigns the specification and it is measured during the standard alignment practice. All indications are that engineering has a good reason for measurement of the parameter. (I don't wish to be rude, but more engineering and less lore would be helpful.) Thanks
    Stuart M Whitaker likes this.
  8. RightOnTime
    RightOnTime Senior Member
    768
    1,640
    183
    Kidnapped in OC, CA
    (1 No, Caster is not adjustable.
    This is due in respect that when your car was assembled from the factory, the accepted castor was within specs. Not every car that comes from the factory is in perfect specs, so Toyota uses a degree of error for each measuring point of alignment.
    (2 The number one killer of tire wear is Toe. Caster only affects your steering output.
    (3 If your car has been in any major accident, your alignment would be off the accepted numbers within the range Toyota recommends.
    Hopefully, I answered your questions! :)
    What is your Toe numbers?
    Gas Mizer likes this.
  9. SagradaFamilia
    U.S.A.
    2018 Prius
    Thank you for that very clear/definitive response, RightOnTime. Just the kind of sage advice I was seeking.
    To answer your question, the post-adjustment toe values are: Left 0.01, Right, also 0.01, both are right at the center of specification.
    Since alignment handling, tracking, and breaking are all well behaved.
    Thank you all!
    Marty
  10. SagradaFamilia
    U.S.A.
    2018 Prius
    Ah, I see I've typed a mistake...The toe values are 0.10 not 0.01...Marty
  11. RightOnTime
    768
    1,640
    183
    Kidnapped in OC, CA
    Very good! 0.10 is within the range of specs but if your mechanic took more time he can get it closer to 0.00. It all depends on the amount of time your mechanic wants to spend on your car. Time is money!
  12. Mendel Leisk
    40,582
    I'm not understanding the above. A "spec" typically is an ideal and an acceptable deviation, for example:
    5.1 degrees plus or minus 0.1 (or 0.2 or 0.3) degrees.
    Addendum: checked the repair manual, think you're good:
    #12 Mendel Leisk, Jun 2, 2014
  13. MSA14
    MSA14 Junior Member
    74
    23
    Metro Atlanta, GA
    You don't necessarily want 0.00 toe - this results in a car will tend to wander on uneven roads. A slight toe-in is preferred over slight toe-out and Zero toe for stability.
  14. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I know from karting, negative toe makes the car darty. We ALWAYS ran toe out
  15. MSA14
    MSA14 Junior Member
    74
    23
    Metro Atlanta, GA
    Yes. Toe out increases turn-in response, but it sacrifices straight line stability. It's amazing how much an alignment transforms a car for track duty - even if it's a show room stock car.
    To clarify, you do know that negative toe is "out" right?
    #15 MSA14, Jun 2, 2014
    RightOnTime likes this.
  16. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Note that someone pulling up to a curb who misjudges and bumps it -can- change the castor. The Prius is NOT a truck. It bends on impact. ;)
    Further, while like most vehicles there is no built-in castor adjustment, it -can- be adjusted. You have to bend things to do so. For example, a solid rear axle vehicle rear castor is adjusted with a tool that bolts onto the axle and bends it. Very high tech -NOT- !
  17. Mr.Electric
    Mr.Electric Member
    287
    103
    San Francisco
    I adjusted caster on a gm by filing the holes in the front strut towers into slots. The hunter alignment rack computer told me to file the holes I'm not making this up!
    I wonder why that wouldn't work on a Toyota too.
    iPhone ?
  18. Mendel Leisk
    40,582
    One problem with any slotted connection, it's relying 100% on the bolts ability to clamp the two surfaces. If the clamping action is overstressed the bolt could end up at the end of the slot, way out of alignment.
    Also a slot in a plate is inherently weaker, more prone to opening/tearing. In structural slotted connections oversized plate washers are mandated, to bridge the slot. When post-slotting an automotive connection if you were to add plate washers you might be exceeding the bolt's length.
    That said, it might still work, lol.
  19. hlunde
    hlunde Member
    419
    75
    Caster is determined by the relative position of the upper strut mount and the ball joint, and these are about 25" apart in the Prius. Thus, a change of 0.75 deg is equivalent to a change in position of the strut mount or ball joint of about 0.32 inches, and the spec is +/- 0.75 deg. This is why it's not adjustable -- it would take serious body or control arm damage to move the strut mount or ball joint by 0.32 inches. If this were to happen, the vehicle would be in a frame shop if not totaled. Wear is another factor, but obviously a ball joint with anywhere near this much wear would separate.
    jzchen likes this.
  20. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    Sounds like my old 1964 Ford F150. it kind of went straight down the road.... It had a big steering wheel, bench seats and a PTO. bored her out to a 312. ran great, sounded like a sewing machine until i blew the head gasket. errrr.
