Cat replaced now heat shield rattles?
Discussion in 'Gen 2 Prius Technical Discussion' started by daisy555, Oct 5, 2022.
  1. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Hi again!
    Would rattling heat shield be related to cat converter replacement?
    Yesterday service made sure everything was secure under car. Noise briefly went away. 45 min drive and it’s rattling again. Not loud just when I put foot on the gas at slow speed.
    Thanks!
    Tombukt2 likes this.
    52,385
    Could be a heat shield not secured properly.
    Did you get a cat shield?
  3. daisy555
    1,727
    715
    CT
    When they checked everything they said nothing was loose. No I didn’t get cat shield. I figured the cost of purchase and installing was more than my deductible but now I worry every time I turn my car on in the morning. : )
  4. daisy555
    1,727
    715
    CT
    Do they remove heat shield when replacing cat? Something must have happened. Can it be a coincidence? I guess anything is possible.
  5. bisco
    52,385
    Is it something that would record well?
  6. daisy555
    1,727
    715
    CT
    No unfortunately. The service manager heard the initial (subtle) sound and thought it was heat shield.
  7. daisy555
    1,727
    715
    CT
    Sounds like a small rattling vent kind of sound under car near gas peddle area.
  8. bisco
    52,385
    Seems like too much coincidence
  9. daisy555
    1,727
    715
    CT
    That’s what I think. From what I’m reading online it sounds like shield gets removed to to repair. Maybe I’m confused. Unless it’s worn out and clamps or bolts aren’t fitting well after repair. Would think they would see that when they checked.
  10. Tombukt2
    Tombukt2 Senior Member
    13,405
    2,415
    Durham NC
    Nah you're in conn. I used to live over in Windsor locks right next to Western Massachusetts near the prison the federal. I can't remember what the laws were for emissions back in the 85. I would have hoped by now they might have gotten a little more lax so that is maybe as long as the catalytic converter is in place it doesn't matter whose it is but I don't know that I know a few states have gotten to the point where they're just not fooling with this.
  11. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    The metal that the shielding is made of can easily be bent... Sounds like all your fasteners are there because the rattling is infrequent. Just got bend stuff to get it to quiet down. Meanwhile, cat shields only cost like $70 and can be installed in a 1/2 hour. You might as well get one if you have to fix the shielding noise under their any ways.
    daisy555 likes this.
  12. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    It sounds like the heat shield to me.
    The cat heat shield is just thin pre-shaped aluminum. It's around the thickness of a disposable aluminum cooking pan for a Turkey.
    If your previous cat was stolen, then any dent/etc in the heat shield, can make the shield be noisy at times.
    It's not dirt cheap. So, they rarely replace it, unless it's very damaged. I think the exhaust needs to be dropped to replace the shield. So, that adds another ~1 hour, or $100-$200 to the replacement cost. There are often nuts/etc that get rusty, and need to be heated off, then replaced, and so on. So, the total time may be over an hour. Add in the cost of the parts, and it's now a $200 to $400 job.
    You can see, and get an idea how the heat shield attaches to the car, in the following video - start around 11:10mins.
    Code:
    Start at ~11:10
    https://youtu.be/fVXOOpw2PJU?t=679
    This is One Toyota Corolla Model You Might Want to Avoid Unless The Engine's Been Fixed
    The Car Care Nut
    In the pictures below, you can get an idea how the cat heat shield is attached on a Gen4 Prius Prime:
    Good Luck!
    #12 prius16, Oct 5, 2022
  13. daisy555
    1,727
    715
    CT
    Thank you. I’ll look into this and appreciate the additional info.
  14. Frontporch
    Frontporch Active Member
    535
    121
    Nj
    If you replaced the catalytic converter after a theft, I have found that its pretty easy to damage the heat shield that is just behind the cat ( and just forward of the resonator). That part may have been cut by the reciprocating saw used to quickly cut out the exhaust. It probably should have been pretty obvious during install of the replacement.
    I have had issues with rust through on those thin shields, especially the one over the muffler. In most cases (assuming rust belt locations) the fasteners may be impossible to remove, but if they can, a good stainless steel fender washer might do the trick to repair rather than replace that part. They seem to rust under the fastener and just fall.
    Worry about theft?
    Since you mentioned worrying about theft, if you got an OEM catalytic converter from Toyota, you should be concerned. If you got an aftermarket converter, the thief should be able to see that pretty clearly and move on. Nobody wants to take a part worth $100 or less when they can get 10x that amount for the Toyota made part. FYI... I would not assume that a dealer used an OEM part. Reach out to the mechanic or check the receipt to see what was installed. A catalytic converter part under 1K is not the original Toyota OEM part.
    #14 Frontporch, Oct 7, 2022
  15. Mendel Leisk
    41,896
    Basically an oversized washer, larger outside diameter than usual for hole size. Good for spanning torn out holes.
  16. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    FWIW, I got newly replaced OEM catalytic converter from the prior owner whose insurance company paid for it just before I bought it.
    Subsequently I bought a MillerCat stainless steel Complete shield system and had my Toyota dealer install it even though I have zero deductible comprehensive insurance but don’t want the hassle of replacing it again nor did I want my policy dinged.
    I noticed that after the MillerCat shield was installed the exhaust system was quieter. I didn’t really notice noise before or was not bothered by it but noticed the lack of it afterwards.
    No guarantees the shield will prevent theft but it’s the best I can do and the noise reduction was a bonus.
  17. daisy555
    1,727
    715
    CT
    Thank you! Insurance would not pay for OEM. The two expensive parts were:
    34532 C $792
    FAP4642 Pipe Assay list price $999 but invoiced at $682
    I tried googling these parts but nothings coming up.
    Dealer checked connections and they didn’t see anything loose. Obviously I need to resolve this to be sure it’s related to repair or not. I think they now think I’m being paranoid. I need to call them today but hoping to get confirmation whether the repair involves removing heat shield in order to replace cat on 2009. Maybe clamps are loose.
    I don’t hear sound when driving on highway. Only during stop and go and putting foot on gas especially on incline.
    #17 daisy555, Oct 7, 2022
  18. Mendel Leisk
    41,896
    You’d think they’d hear it, if they bothered to test drive.
  19. daisy555
    1,727
    715
    CT
    I went on test drive with him and it was very subtle. Bringing it in on Monday for another test drive. Hopefully we can find a hill. It’s feeling like I might have to convince them it was caused by repair. : / It’s probably something loose or bent on the heat shield but not visible.
  20. daisy555
    1,727
    715
    CT
    Thank you everyone for your help with this!
    Turns out they found defective gasket at cat and manifold flange. (?) Replaced the non OEM gasket with an OEM gasket. Glad I pushed for this to be fixed.
    Apparently there is some decay on another part near this area but unrelated to cat theft. I didn’t write down the issue but was told it could take some time before it needs to be replaced. Something that I might notice as it gets colder? Approx $200 repair which won’t be too bad.
    So relieved they found the issue! Now I can stay focused on new car purchase. : } I let go of the silver Prime XLE that’s arriving in a few weeks due to it missing a few safety features that the Prime Limited and Prius XLE have.
    #20 daisy555, Oct 10, 2022
    bisco and Mendel Leisk like this.
