Cat theft, check engine, and red triangle
Discussion in 'Gen 2 Prius Main Forum' started by fach, Mar 23, 2021.
  1. fach
    fach Junior Member
    28
    24
    Hi forum, I hope somebody can help me out. My car was perfect until my catalytic was stolen. It has 80000. I read in the forum, and I bought a generic catalytic from amazon with the Denso 234-4623 Downstream sensor. The cat replacement arrived early; I when ahead and installed that. I was available to drive to work and drive back. However, on my return, I noticed a fan by the passenger seat kick in. When the car was cold, I installed the sensor. I took the car for a drive, and it was rough and lack of power. I read the vehicle with a generic obd2 reader, and P0138 was present. I turn off the car, reset the code. After that, I drove for about 10 min, and the vehicle was fine! Today, I started the car, and I have checked the engine, exclamation mark, And red triangle. The car drove fine. However, I am worried about the three extra lights in the dash (check engine, exclamation mark, and red triangle). Could somebody please give me any idea what to do? Thank you
    #1 fach, Mar 23, 2021
  2. PriusCamper
    PriusCamper Senior Member
    13,080
    5,306
    Pacific Northwest, USA
    I live 20 minutes south of you... Those warning lights store error codes that point to what the problem is. My best guess is that while your car sat for a while awaiting a replacement catalytic converter you're hybrid battery discharged to the point of throwing warning codes and computer shut down the hybrid system to protect it.
    You can clear the codes by disconnecting 12v battery for a few minutes. You can also try to force charge it by putting the car in drive, left foot on brake, right foot floors the accelerator.
    Also for less than $30 you can buy an OBD2 code reader that plugs into the car that will allow you to use a phone app like Dr. Prius app to read and clear those error codes and subcodes. Here's a buyer's guide: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Alternatively if you stop by my place I can do that for you...
    Meg&Bear, fach and Raytheeagle like this.
  3. fach
    fach Junior Member
    28
    24
    Sir, that will be nice of you. I own a wire and that I was using in my previous car (civic). I will try to reset the codes with my wire and and if I run into troubles. Would you please help me out? I will send you a pm with my info. Thank You so much!
    PriusCamper likes this.
  4. lexidium
    lexidium Active Member
    302
    143
    manchester
    Are you sure you've got the wiring right on the denso sensor?
    You can get the Denso one. Works fine but the wires are a different colour.
    I stripped them and joined it inside a plastic junction box.
    The 2 whites go to the blacks on the denso
    The black goes to the blue on the denso
    The grey goes to the white on the denso
    Meg&Bear likes this.
  5. fach
    fach Junior Member
    28
    24
    Sir, I thought that the Denso 234-4623 was a direct replacement, and it does not need any wire cuts.
  6. lexidium
    302
    143
    manchester
    Apologies.
    I assumed that since they took the cat, they must have cut the wires on the sensor.
    fach likes this.
  7. PriusCamper
    13,080
    5,306
    So I drove to OP's house last evening and loaned him an OBD2 reader and showed him how to read and clear error codes and keep an eye on temperature via Dr. Prius app so he can get a little more life out of his battery pack before he pulls it and works on it.
    He's an ideal candidate to rebuild his own pack as he's experienced with DIY car repairs and recently bought a B6 SkyRC type charger to successfully repair a dead vacuum cleaner robot he bought for $10. So I'll be hooking him up with a replacement module or two and others on here who have pack rebuild experience can be helpful with this process too.
    Here's screenshots. The voltage difference when car first started but before I grabbed the screenshot was 1.34v, s he definitely has one or more bad cells.
  8. fach
    fach Junior Member
    28
    24
    All,
    I have the fortune to have a PriusCamper near me. I was under stress due to my rocky status in the Prius car. After I spoke with PriusCamper, I feel more confident now. I am a hands-on guy, and I do a little bit of everything, and I did for some time electronic soldering from bios Chip to BGA chips. I am hoping for your wisdom and help.
    #8 fach, Mar 24, 2021
    Meg&Bear and PriusCamper like this.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,094
    1,998
    NJ-USA
    The thieves usually do cut the wires, but those exposed wires are part of the sensor. The connector is inside the car. So you unplug the old connector and cut wires- install the new sensor and pass the new connector through a hole in the floor and plug it into the vehicle harness.
  10. fach
    fach Junior Member
    28
    24
    Sir,
    In the beginning, I thought the new sensor or aftermarket cat was the culprit of this “red triangle of the dead.” it looks like These parts are good. Apparently, it was my luck that after the catalytic was stolen, a couple of days later, the battery starts to miss behave. About the sensor, I lift the passenger side carpet to install the Denso sensor. I will upload pictures of aftermarket catalytic and sensor asap I meet the requirements.
  11. fach
    fach Junior Member
    28
    24
    I little update. I drove the car today, the first time after the codes were clear. My commute is about 20 min, and I notice the battery was charging about five lines and discharging fast. On my return home the car trough a p3000.
  12. PriusCamper
    13,080
    5,306
    P3000 is simply detecting the brief voltage difference in block #9 because of bad cell... The fast charging and discharging is a sign of lost capacity, usually down to 50% capacity at this stage. Here's the science of it: BU-807: How to Restore Nickel-based Batteries; Battery University
    Here's the FAQ for a charger/discharger system, which because of your electronic experience you can build yourself via @alftoy who is currently building one for less than $100: FAQ (Frequently Asked Questions) | Hybrid Automotive
    Will offer more details tomorrow.
    Meg&Bear and fach like this.
