Catalytic / check engine light
Discussion in 'Newbie Forum' started by toobz4this, Jul 16, 2020.
  1. toobz4this
    toobz4this Junior Member
    North Carolina
    I had a top engine clean done on my '08 and then the check engine light came on and the tech said the Catalytic converter is bad. Car was fine going in for oil change came out with needing converter replaced. I was angry and told them that they broke it doing the engine clean. So now I am stuck. Is there anything I can add to the fuel to clean the catalytic converter? I had someone tell me to put about 3 gallons of racing fuel in the gas tank and it will burn the crud away. I hesitate to do this without chatting it out with you all. BTW, my Prius has over 200K miles, runs great, gets 45mpg. I cannot afford to replace the converter, part alone was going to be $2200.
  2. jimontheocean
    jimontheocean Member
    53
    46
    SC
    You could try cataclean from auto store. I have had about a 50% success rate with it.
    To me, it would be worth a try.
    Did you check the codes yourself?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Most 'racing' fuel has lead as an additive. Lead is a contaminant for catalytic converters and will cause failure. Granted, I am not a catalytic converter expert, but I would be very hesitant to follow this advice. I would be much more likely to disconnect the 12v battery for a few moments to reset all codes and see if it ever comes back.
    What are your car inspection requirements in NC? Is there an annual inspection or similar? Even with that code, your car is likely to have emissions better than 90% of the cars on the road.
    If this becomes a necessity, I could help you out with some much less costly options, including potentially no cost.
    #3 TMR-JWAP, Jul 18, 2020
